Mowing Which Rotary Cutter
   / Which Rotary Cutter #1
ala55
Salisbury, NC
John deere 3520
What width rotary cutter are all the 3520 owners using? There is plenty of HP but Im not sure of the weight.
   / Which Rotary Cutter #2
Have a MX5. Works very good but do feel the weight some. Tried out 6' brush hog, power was no issue but weight felt a bit much. lightweight 6' may be okay but they get a rough shape quick
   / Which Rotary Cutter #3
The 3x20 series is deceptive, because it has such fantastic lift capacity & hydraulic flow rate... capabilities on a 2900# machine that would suit a 4000# unit.
It seems like 90%+ are either a lighter 6 footer or a medium duty 5 footer; either covers the tracks. With the loader on & loaded tires the are different machines that dry/no loader. Biggest cutter I have seen people using are the medium duty 6 footers, but get up over 1000# and theres a lot of leverage picking up the front when its raised.
I would look to Woods, bush hog, brown, rhino... I have an MX5 with the flawed output shaft & JD's bolt-on fix is a $2200 one, and they've broken at a rate that would have an automobile manufacturers line pulled off the highway. Based on this experience, I could never recommend their product... shortly after the initial purchase, before the breaking started everywhere, I still saw the listed manufacturers were more robust, had higher brush diameter ratings, a gauge up on the deck, and in Woods case, exceeded the blade tip speed on the mx lineup. I had buyers regret from not doing more research on the options, and the 0% for the cutter with the purchase made me an easy sale.
The other medium duty cutters are 10-25% heavier, so push the limits, not of the hydraulics, but frame capacity... still people run them successfully, just have to keep the front down/heavy.
Figure out what your application is, then go up a size!
   / Which Rotary Cutter #4
I'd go with a 5 ft rotary cutter on the 3x20 series tractors mainly due to weight. I have a 6 ft Frontier (light duty?) on my 4320 and it doesn't work as well on my 3720 due to weight. So, I run a 5 ft Bush Hog (Squealer 60) on the 3720 and it works great since it is less weight. I have some steep hills that are a factor in using the above configurations.
1990 GMC Topkick Grain Truck (A50514)
1990 GMC Topkick...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2014 Ag Spray Schaben Sidedresser (A52748)
2014 Ag Spray...
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
