Rotary Cutter Which rotary cutter to get
   / Which rotary cutter to get #1
gharms
Barneveld, Wisconsin
MF 1648 12x12PS
Hi All,
I am currently looking to buy a rotary cutter for my Massey Ferguson 1648, and am wondering what you guys would do. I have 38 PTO HP on my tractor. Have about 8 acres to mow, nothing of it is part of the garden. Currently it is in pretty rough shape, with lots of small brush and prickly stuff growing. I am undecided between the Landpride RCR1272 (light duty; 1 inch cutting capacity) and Landpride RCR1872 (medium duty; 2 inch cutting capacity). Both have a PTO hp rating that is compatible with my tractor (my tractor being a little above the minimum PTO hp required). This rotary cutter will also be used to maintain the grassy sides of my driveway.
My guy is leaning towards the RCR1272, but I don't know whether it is worth to forgo the bigger drive train and bigger cutting capacity and longevity of the RCR1872 to save a few dollars as the difference between them is not that big (300 $). I plan on mowing every few weeks.
Thank you for your input,
Gerda
   / Which rotary cutter to get #2
Get the heavier one imo
   / Which rotary cutter to get #3
I recently went through a similar decision (but looking at 4' or 5' models). I chose the 4' RCR1248 because most of what I do is trails, very light duty, and no bigger stuff. Plus, I won't be using it that often.
For your needs, though, after looking at the 2 side by side, I would spring for the extra $300 and get the RCR1872, especially looking at the 6' size. Just my opinion...
   / Which rotary cutter to get #4
I don't think I have EVER regretted spending more for a better/heavier tool, regardless if it is a tractor implement or power/hand tool. The pleasure of using a well-made tool reoccurs each and every time it is used, which for your cutter, sounds like it will be many, many times. Go for the better/heavier one!
   / Which rotary cutter to get #5
I try to buy the best, heaviest duty equipment for my needs and never regretted it, I would go with the bigger one. I have been using an RCR2672 for several years as I have a ot of brush and it has held up very well. I would recommend chains on the front and back, I got mine with them only on the front and later put them on the back; much better.
It sounds like you guys are thinking similarly to me, so I am not such an oddball. Then I have one more question: Would you go indeed with the six footer 1872, or one size below, the 1860? As I understand the minimum PTO hp requirement for the RCR1872 is 30 hp, and the smaller starts at 20 hp. As I stated earlier, my tractor has 38 PTO hp.
Gerda
   / Which rotary cutter to get #7
Personally, I'd go with the heavier one as well. You don't mention the width of your tractor. I'm going to assume it's about 6 ft wide. The 6 ft cut in heavy brush will probably require you to go to a lower gear but you will "cut your tracks" out. It's much easier to use a rotary cutter that is as wide or wider than the wheels on your tractor. Once you get everything cleared off, I believe you'll be happier with the 6 ft model for future mowing.
   / Which rotary cutter to get #8
With 38 HP, go with the 72
The tractor is roughly 66 inches (5.5 feet) wide. From that point of view I would prefer the 6 footer myself. And it is best to take it really slowly during first time mowing anyways, since I don't know what goodies are under that tall grass and in the shrubs. But I will make a hunt for stones and other big ticket items before going in with the mower.
   / Which rotary cutter to get #10
With only eight acres there won't be much difference in cutting time, so that won't be an issue, but as others, I prefer one that covers my tire tracks so a 6' would be my choice.
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
2016 Ford Escape AWD SUV (A50324)
2016 Ford Escape...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2021 CATERPILLAR 317 EXCAVATOR (A51242)
2021 CATERPILLAR...
2012 Cadillac SRX (A50324)
2012 Cadillac SRX...
John Deere 693 Corn Head (A50514)
John Deere 693...
