Which Quick Connects
   / Which Quick Connects #1
wvpolekat
Platinum Member
Buckhannon, WV
1947 Ford 2N and 2003 Kubota B7500
I am going to be adding 2 more valves bringing me up to a total of 3. All of the lines are going to be 3/8" and I am going back and updating my current front remote to 3/8" because the 1/4" QDs don't flow enough.
I was putting a parts list together at Surplus Center and there are a few choices in 3/8" QDs.
There is the 3/8" safeway: https://www.surpluscenter.com/item.asp?item=9-6347&catname=hydraulic
There is the 3/8" NPT QUICK COUPLER F/F https://www.surpluscenter.com/item.asp?item=9-7381&catname=hydraulic
Both have the same pressure and flow ratings. The second one, I can just buy the halves as well as a set. This is appealing because I can then buy just the parts I need to add different things to my remotes. I guess if I make them M/F on the tractor side, I would just get another set to put on the tool side.
Either way, what say the wisdom of TBN? Does it matter?
On a related note, since QDs cause a restriction, would it be wise to adapt up to a 1/2" QD with 3/8 hose?
   / Which Quick Connects #2
I posted a cross reference chart on here somewhere, but can't remember the title. If the GPM's are that critical, they recommend to go up one size on the QD's.
1994 MACK RD688S BOBTAIL VACUUM TRUCK (A53843)
1994 MACK RD688S...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
safety baskets (A53421)
safety baskets...
Jack Daniels Sign Decor (A51694)
Jack Daniels Sign...
1979 MACK R MODEL (A53843)
1979 MACK R MODEL...
