Which Oil for a Case-IH DX-33
   / Which Oil for a Case-IH DX-33 #1
tkcomer
Maysville, KY
JD 3039R
Getting ready to come up on my 50 hour service. The manual states to use 10W-30 or 15W-40, depending on temperature. But it doesn’t say what type. Am I supposed to run automotive type oil like Pennzoil or a diesel service type oil like Rotella?
   / Which Oil for a Case-IH DX-33 #3
DONT use "automotive" oil in it. If it isnt diesel rated..pass it by
That’s what I thought. But I didn’t see “Simon says” in the manual. Thought it might be a trick question. Rotella it is.
   / Which Oil for a Case-IH DX-33 #5
As the others said.. you must pay attention to oil application.. big difference in spark vs compression oils. Did your manual not give you a spec number?
I'm in florida.. and our NH/case dealer sells 15w40 oils..e tc.
Soundguy
The manual said what weight oil to use, but did not mention what service grade to use. That’s what confused me. My other tractor manuals were very specific about what grade to use. My Case-IH 685 manual is kinda confusing. In the temperature chart, it says multi viscosity oils not recommended. But has two part numbers for “Genuine Case-IH oil” that is approved for use in “your” tractor, and one is for a 15W-40. That’s why I’m asking now. In two months this town will be wiped out of any type of oil for diesels.
   / Which Oil for a Case-IH DX-33 #7
</font><font color="blueclass=small">( The manual said what weight oil to use, but did not mention what service grade to use. That’s what confused me. My other tractor manuals were very specific about what grade to use. My Case-IH 685 manual is kinda confusing. In the temperature chart, it says multi viscosity oils not recommended. But has two part numbers for “Genuine Case-IH oil” that is approved for use in “your” tractor, and one is for a 15W-40. That’s why I’m asking now. In two months this town will be wiped out of any type of oil for diesels. )</font>
You can use any brand of 10W-30 oil thats DIESEL rated...trouble is..they are DA**ED hard to find!! Shell Rotella-T 10W-30 is...but the only place that would even order it in for me was NAPA...by the case...$2.95 a qt!!
I said the heck with it and went for Rotella SYN 5W-40 for $18.95 a gallon at TSC.
   / Which Oil for a Case-IH DX-33 #8
I believe Case I-H calls it #1 (it was originally developed by I-H after Exhaust Valve failures with gasoline Spec oil-)
Sakai SV70TB (A42021)
2008 KALYN BLENDER (A45333)
2008 KALYN BLENDER...
2011 DRAGON PRODUCTS 150BBL ALUMINUM VACUUM TANK TRAILER (A45046)
2011 DRAGON...
Knapheide 8' Mechanics Body (A42021)
Knapheide 8'...
2019 Ford F-150 XL (A44501)
2019 Ford F-150 XL...
40' High Cube Multi-Door Container (A42021)
40' High Cube...
