Which of these two?
   / Which of these two? #1
blackburb
Ariens SRM626
So looking to replace my ancient Ariens rider as the motor is just about dead. I have a flat, 3/4 acre yard. These two are probably more than I need, but they've caught my eye and curious what the experts think. I need to stay under the $1400 stimulus 😉
1) 2003 JD LX277 AWS. 17hp Kawa, K62 trans, 48", 617 hours, $1200. I like the Kawa, and the K62, but a bit concerned about the all wheel steering from a maintenance/repair standpoint. 48" is definitely big for my yard (it's broken up into 5 small areas by bushes, garage, storage building, etc.
2) 2008 Simplicity Broadmoor 20H. 20hp Briggs Vanguard, K57 trans, 44", 418 hours, $1400. Looks to be in somewhat better cosmetic condition and has 200 fewer hours.
Both are located around two hours from me but in the same general direction so I could look at both in one trip.
Thanks!
   / Which of these two? #2
I'd get the Simplicity just because I think it sounds like a better and newer machine.
   / Which of these two? #3
Both of them are priced a little high but I would drive past the Simplicity to buy the Deere.
Don't be shy about the AWS. Like Martha says, "It's a good thing."
   / Which of these two? #4
blackburb where u be?​
I will sell you my cub cadet! 6 hours cutting grass
time. Put a electric fuel pump on it starts right up
no grinding on starter
willy
   / Which of these two? #5
Condition and care is likely the deciding factor. Both are good machines, but like SteveM said, 200 fewer hours and 5 years newer and if what you indicated was a better kept machine - I would vote Simplicity.
I agree for the age, both are about $2-300 overpriced IMO but depends on your local market too.
New 12x20 Steel Carport (A50774)
New 12x20 Steel...
CAT Skid Steer (A50322)
CAT Skid Steer...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
Pickup Truck Bed (A51691)
Pickup Truck Bed...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT6DH646717 (A51572)
2013 Dodge Charger...
2020 GMC 2500 HD (A50120)
2020 GMC 2500 HD...
