Which mower
   / Which mower #1
jmt1271
Platinum Member
MO
Kubota L2501
I have decided to sell my Cub 3200 GT and get an RFM for the JD3520. We are moving to a bigger parcel of land, probably a 13 acre spot we are currently working on. It has about 6 acres of yard. Would a 72" RFM be the best way to go, or will I need both a finish mower and bushhog? Which brands are considered good buys?
   / Which mower #2
Hard to go wrong with woods, landpride, bushhog.. etc.
If you are going to mow -any- significant brush.. you want a rough cutter... nothing tears up a finish mower like mowing brush with it..
If the stuff ( individual stems ) is too big for a push lawnmower.. it is too big for a finish mower..
Soundguy
   / Which mower
Soundguy
Never heard it stated that way, makes sense. The property has around 5-5.5 acres of "yard". I walked it and it looked as if it could be mowed with a push mower(as far as size of material, wouldnt actually push it). My concern was if I ever let it get away from me. I think I will look for a good used bushhog and finish mower. Probably could find both used for the price of one new finish mower. Once I sell the Cub that is what I am going to do. May get lucky and work out a partial trade.
   / Which mower #4
If it's good like you say.. it sounds like a finish mower is fine.. however.. if you ever let it go.. it will be a job. Finish mowers are not great in tall grass... they can suck alot of hp.. bog and clump... They are pretty much good for whatever a lawnmower can mow over... get much over 6" and it is a job and the look of the cut will suffer.
Soundguy
   / Which mower #5
I agree with Soundguy. My property profile is similar to yours (12.5A's). I maintain ~2A's of "lawn" with a rider mower and ~6A's with a 60" rotary cutter on my tractor. As Mother Nature is always one step (or 3) ahead of me I often have to mow my "lawn" with the RC. The cost of a cheap rider mower is comparable to a RFM, a rider mower will not tear up your lawn like a CUT with weighted R1's, and it is another "toy" to get by "She Who Must Be Obeyed" :D. I would recommend a rider mower and a rotary cutter.;) Jay
   / Which mower
I actually have a "new" Cub Cadet 3200 I mow about 1.5 acres with now. When we move I will be mowing much more. That is why I am going to try to sell the 3200 with 54" deck and get as big a finish mower as my JD will handle. I need to get down to one machine to maintain and store, as well as maximize my use for the "big" tractor.
   / Which mower #7
We have lots of satisfied customers using the First Choice mowers. 6 FT $1395 + shipping.--Ken Sweet
Email sweet@scrtc.com
Mower picture http://www.sweettractors.com/newpics/12902/firstchoicefinishmower6.jpg
   / Which mower
Ken, roughly how much would shipping be to a local truck terminal in 38351. This would be a commercial delivery to a dock, no residential, or liftgate required. What other brands do you carry?
   / Which mower #9
I recently purchased a used Landpride FDR2572 for $1200. You can see pictures of it in my gallery. It was in good shape and the same unit would have cost me at least $2300 new in this area with pneumatic tires. It came with a spare tire and a spare blade. The only option it did not come with was the anti-scalp roller but I recently ordered this and I will be adding it on.
I usually prefer to buy new and I was about to buy a First Choice unit since they seemed like a good value for the money. However, I had always wanted a heavy duty Landpride FDR25 series but I wasn't about to pay over $2000 for a mower. I had to take the chance with used when this came up.
The gentleman I purchased it from was using it to "roughcut" his fields a couple of times a year. There probably was not too much heavy brush in the fields but I'm sure it was pretty thick grass. He said he had over 300 acres and was using it on a good portion of this, which I find hard to believe. Ultimately, he only used this for a couple of seasons then he traded up for an 8' unit. Considering this "abuse", it was in pretty good shape. It was always stored indoors. I simply sharpened the blades and greased all the fittings. It did have one bent blade so I replaced it with the spare. The metal dividers below the deck were also bent but were easily bent back into place. The gearbox oil still looked like new in it. In terms of rust, I have seen new ones on dealer lots that looked worse than this one. This unit seems to stand up well to the abuse.
Since he had already put it to the test, I decided to do the same. I mowed about 4 acres of wild field with it to see how it would do. The field was mostly thick grass & weeds. There was little to no heavy brush. The grass was easily taller than the operator platform in most areas and up to 4' in others. I kept the FEL on and simply lowered my bucket near the ground to push over the grass and probe for large mounds and rocks. I also kept the mower deck fairly high off the ground on the first pass and went slow. It mowed it without a problem and my 3320 rarely even bogged down. However, I did notice my ground speed slowed down a few times, presumably due to the load match feature.
With all of that said, the cut was not the greatest but it is coming around quite nicely after an additional pass. One or two more passes and you will have never known it was a field.
Assuming you have no major brush, I would start with a heavy duty RFM. Your machine can certainly handle it. If you are not happy with the results, you can always buy an inexpensive new or used Rotary Cutter later. The ideal thing would be to have both but it will cost you more and it takes up more room if you plan to store it indoors.
I can tell you one thing, I would certainly recommend the LandPride FDR2572 after seeing the way this thing has held up.
Whatever you get, make sure it is iMatch compatible if you have an iMatch.
   / Which mower #10
Wow.. I wouldn't even consider cutting 5-6-7' tall.. -anything- with a finish mower that i paid for... That's deffinately rough cutter teritory!
Glad you had good luck with it.
Soundguy
2015 KC TRAILER 130 BBL STEEL VACUUM (A50854)
2015 KC TRAILER...
2016 Ford F-150 Crew Cab Pickup Truck (A49461)
2016 Ford F-150...
2017 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A49461)
2017...
2023 Ram 4x4 Pickup Truck Bed (A49461)
2023 Ram 4x4...
EVERYTHING SOLD AS-IS WHERE IS!! (A50774)
EVERYTHING SOLD...
2018 John Deere 35G Mini Excavator (A49461)
2018 John Deere...
