I have a 20+ acres property in Nova Scotia, Canada. Around 10 acres is a field with some steep slopes. I want to buy a tractor and decided to go for a Kubota. Which is the right one?
For mowing I figured that, given the slopes, width and wheel base in relation to ground clearance are a factor. I don't necessarily want the heaviest possible thing and mowing is what I will mostly do. However, once you have the tractor, things like snow plowing and taking care of the other 10 acres with a lot of dead wood and trees come to mind.
Would the bx 2660 do or should I go for the b 3200? The smaller b's don't seem to make sense as they are almost the same width as the bx and have a higher point of gravity.
I appreciate your input. Best from sunny Nova Scotia, toon
