Which kind of drain pipe to use?
   / Which kind of drain pipe to use? #1
VinnieNC
Eastern NC
JD 5310
I am installing a drain line for a sink in my workshop. The line comes out below the concrete slab at a light grade for gravity flow. I want to make a drain line about 25 feet long for the sink water to drain into. There is no tank involved as I don't expect to be draining anything but dirty, soapy water.
I plan on making the ditch about 18 inches wide and 18 inches deep and about 25 feet long with No. 5 gravel in the bottom and covering the drainage pipe.
Question:
Which type of drainage line should I be using? I have see the black plastic with roughly 1/2 inch holes and with slits. Should I put one of those stockings on it?
This drain will probably only see about 5 - 10 gallons per month, but I want to do it right the first time.
Thanks in advance for any advice.
-Vinnie
   / Which kind of drain pipe to use? #2
Vinnie..once you get beyond the slab it's kinda 6 of one, half dozen of another. There is also white thin walled perforated pvc drain pipe available. Put most of the gravel in the bottom and run the pipe a little higher in the trench so the water has someplace to go. landscape fabric should help keep the dirt out.
Of course you know, we all expect you to keep your word about not introducing anything hazardous in nature....Right
   / Which kind of drain pipe to use? #3
Is this legal to do in your state/county?
   / Which kind of drain pipe to use? #4
Use perforated PVC. The corrugated black drain pipe is cheap, but till trap any sediments in the corrugations. Also, IF you ever have to clean the line, you can run a snake through the PVC. No way to get a snake past all the corrugation...
I am not sure of the legality in my county. The permit for the building was for storage only, no water or electricity. When it was inspected, there was a pile of scraps on top of the drain pipe stub, ooopps! I have since wired it per code, just no permit or inspection. And now I want to put in a handwashing sink.
Thanks for the advice on the PVC and landscape fabric. I have some fabric left over from a landscaping project. I think I will add a cleanout port just in case.
-Vinnie
   / Which kind of drain pipe to use? #6
I'm glad I don't live where there are that many regulations. I understand where it's more crowded, you probably need that to help keep people straight. I'm glad I don't need a permit to run a drain line off a storage building sink.
Good idea on the clean out port. We had to run a pig in a neighbor's shop line from the discharge end and made a mess in the shop. Clean out port would've gotten it a lot easier. I also agree with perforated PVC and gravel.
   / Which kind of drain pipe to use? #7
I would use the perforated PVC. Fill the trench with gravel or other material. I've seen styrofaom popcorn, foundry slag, busted up bricks and straw used for this.
To cover the material in the trench, tar paper works well, and so does plastic sheeting. I've even seen house wrap used. The cover material is to keep surface water and fine particles out of your leach field.
Eddie
   / Which kind of drain pipe to use? #8
Believe it or not, they use newspaper on (county inspected) septic leach lines around here!
   / Which kind of drain pipe to use? #9
If you are going to drive your tractor over it use heavier pipe since its shallow. Schedual 35 or i've even drilled holes in sch 40 myself. You could dig a little bigger hole at the end of the ditch and fill with rocks for a mini dry well.
Larry
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
ASCO Transfer Switch (A52377)
ASCO Transfer...
2015 INTERNATIONAL 4300 26' REEFER BOX TRUCK (A54607)
2015 INTERNATIONAL...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
WB Mower (A50120)
WB Mower (A50120)
