Which is better?
   / Which is better? #1
Pozzman
MO
1702 Yanmar
I am lookig for some wisdom from some experienced Kubota users. I found two kubotas in my area was wondering which would be the better tractor.
B2150 4wd w/ loader, 330 hours, asking $8500 or B7500 4wd, w/loader and
60" belly mower, 530 hours, asking $8500.
It appears HP wise the B2150 is a littel stronger. Are there any advantages/disadvantages from one over the other?
   / Which is better? #2
What are you hoping to do/manage with the tractor? A little info would be helpful.
   / Which is better?
I will use the tractor for brush hogging (5- 7 acres) clearing cedar trees that have already have been cut down, put in a food plot and maybe an acre garden or grape vines. Also use it to keep clear a short trail in the woods.
   / Which is better? #4
I don't know anything about the 2150, i do know that the B7500 is a workhorse. I purchased a new model in 2000, worked the tail off it for 6 seasons. Never had an issue with the exception of a front axle seal that i blew by doing heavy fel work without a counterweight. B7500 is a proven machine in the kubota line up.
   / Which is better? #5
I think that they are both good tractors, but for me the advantage would go to the B7500 because of the current availablity of front mounted attachments, etc. I would check with a Kubota dealer about what is still available for the other tractor.....
   / Which is better? #6
I think you should keep looking. For what you've planned, something of around 30HP that weighs 2000 lbs. or more and can comfortably handle a 5' bush hog would be about right. New, I'd say the L2800 is a place to start. New Holland's got a deal going now on the TC30, which would be nearly perfect.
Bush hogging 5 or more acres with something as small as a B7500 will be very tedious.
Bob
   / Which is better? #7
The B2150 is a 24hp 4cyl cut that weighs about 1700lbs without FEL. The B7500 is 21hp and about 1400lbs. I think the 2150 is a slightly larger chassis size also as indicated by weight and would probably meet your needs better. As others have said tho.... 5-7 acres is quite alot to brush hog with a 5ft cutter. A 5ft might be pushing it as the 2150 is only 18hp at the pto. I run a 4ft behind my 2400 (24hp eng...18hp pto) but I believe the 2150 has more torque than mine as it's a slightly larger engine besides being 4cyl vs 3cyl.
PAIR OF UNUSED 60" HANG ON FORKS (A54757)
PAIR OF UNUSED 60"...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A53473)
Quick Attach Skid...
2018 JLG 10054 TELESCOPIC FORKLIFT (A51406)
2018 JLG 10054...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
