Grading Which is better Front or Rear Blade?
   / Which is better Front or Rear Blade? #1
woodstock
Winnipeg, Canada
BX2200
Do you need both or is one better than the other for every thing or does each have some benefit?
Can you guys help out with your experiences?
Does anyone have both?
<font color=red>Winnipeg, Manitoba</font color=red>
2001 BX2200 (50 hrs)
   / Which is better Front or Rear Blade? #2
I have both that I have used with a 5000lb tractor (4.2K or so with rear blade on)
A front blade on a tractor this size is pretty much worthless with a couple of exceptions. The front blade I have that replaces the loader bucket can be angled in a couple of directions by "tilting" it, which unfortunately also changes the angle of the cutting edge. Even so it is good for doing light landscaping of slopes of ALREADY loose, rockless ground. I hate trying to look backwards and wreck my neck (talk to old guys with lots of hours) using a rear blade to angle slopes. The front blade will just throw the tractor up off the ground if it hits anything remotely solid. If you have a "real" front blade, one that mid mounts you'll do better. For out and out digging a rear blade is best, just as a rear anything seems to work better. I use the front blade going backwards, tilted forward it is great for just removing sod and leaving a flat surface for gravel. It also works great (with it's "legs" on) to move snow. It's not a snow blade it weighs probably 800 lbs. Also works beautifully for spreading gravel.
I just need to figure a way to drive my tractor facing backwards! /w3tcompact/icons/smile.gif
Any heavy work is better with a rear box scraper or the local rental yard D3 cat.
del
   / Which is better Front or Rear Blade? #3
Woodstock
I have both. According to Curtis 6 1/2' blade can be used for dirt. I have not had much success. The main reason is with the front blade mounted on FEL frame it is hard to get the adjustments that I can with rear blade. A dozer type blade mounted in place of FEL may work better.
Having T&T on 3PH helps a lot. I helped a neighbor fill in a trench he dug. Tried to use front blade. Could not control it good enough. Went back to barn and put FEL bucket and rear blade on. I was able to close up trench without problems. I don't like looking backwards all the time with rear blade. But it sure does a good job.
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
International 1066 2wd tractor (A52128)
International 1066...
John Deere 331G Compact Track Loader Skid Steer (A50322)
John Deere 331G...
2017 Buick Encore SUV (A50324)
2017 Buick Encore...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
