Which injector is guilty
   / Which injector is guilty #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
The tachometer on my MF 261 swings back at regular intervals so, I suspect a problem with one particular injector. Is there a quick and painless way to find out which injector is in need of service? I've thought of an engine stethoscope or an infared thermometer.
   / Which injector is guilty #2
I would crack the injector lines at the injector one at a time while the engine is running until you notice no or little difference in engine operation from one of them. By cracking, I mean loosen the injector nut until the diesel is dripping off of the threads. If it is dripping off of the threads it will not have enough pressure to be injecting into the cylinder. If one is not operational, you will not notice a difference in the engine tone. Do not take the nut fully oft to prevent contamination.
Tom,
Thanks for your reply. At this point my query has has 197 views and nobody else has responded. I guess you nailed it on the first effort.
   / Which injector is guilty #4
If you have a dead injector the infrared thermometer aimed at the exhaust manifold will show a cold/misfiring cylinder. Cracking an injector line as previously mentioned will help detect a misfiring cylinder.
Timster2,
Thank you. I've been looking for an excuse to buy one of those infared thermometers.
   / Which injector is guilty #6
The infrared thermometer is a very useful tool that I use often. Anything that involves heat including but not limited to, brakes,cooling systems, exhaust, tires, bearings, wiring, HVAC, insulation can be diagnosed with infrared. Automobiles, trucks, tractors or just about anything with an engine is one big heat exchanger. Fuel in, combustion, heat out, minus friction, brakes, bearings etc.
(1) FRIGIDAIRE REFRIGERATOR (A51248)
(1) FRIGIDAIRE...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
2020 KUBOTA RTV...
