Which Hitch??
   / Which Hitch?? #1
jpwazz
My back tells me it's time for a quick-hitch but which one? After scouring the web they all seem about the same (ASAE spec) other than drastic price difference. My local JD dealer wants $300, "Fleet" type store around $200 for Speeco, or there's Landpride, Woods, etc.
Any advice? JP.
   / Which Hitch?? #3
I have the Land Pride Cat 1 QH and IMHO or maybe not so humble opinion it is the best one out there. The top link hook is adjustable up and down (4 or 5 positions) and it waaaaaaay over built! It cost me $300 and I would pay it again in a heartbeat! Good Luck and enjoy the hunt! :p
Troy
   / Which Hitch?? #4
JP,
TSC has a cat 1 Speedco which is made in Colorado buy a company I can't think of right now. I have one and the price was $224.00 and it has an adjustable top hook and is built like a tank. I compared it to the Land Pride's QH and the only difference I could see was the color and $$$$. Speedco= yellow, $224.00. Land Pride--black, $350.00. Now which one would you buy?
DevilDog
   / Which Hitch?? #5
I bought a Cat II Speedco hitch 2 weeks ago and have tortured it with several hours of heavy box blading and it has held up well so far. I also have done several implement changes with no issues. It costed $259 at Rural King
   / Which Hitch?? #6
Don't want to start a china debate here but just ordered mine from Harbor frieght yesterday (its on sale this week for 79.99), got the optional hitch adapter 8.76 used my 20% one item coupon and with shipping to my door from CA to WI 82.75...... got confirmation this morning both are shipping out nothing backordered.. quick advice if you go this way call in your order if you want the adapter you can't get it online even if you try to add it with the "order from catalog #"
   / Which Hitch?? #7
I got a Johndeere imatch for $225. Try to lower their price. Thats what I did.:D
   / Which Hitch?? #8
Any advice? JP.
might be cheper to spray paint some marks onthe ground so you canback up straight and not have to stran to hook things up.. hookup the fixed arm first.. then use the adjustable arm to amke the second connection.. then adjust the 3rd link...
if you lined up right.. all you are lifting is the individual lift arms and sliding them on pins and then dropping lynch pins in.... then turning a hand crank or turnbuckle for the other 2 links to make adjustments..
soundguy
   / Which Hitch?? #9
JP,
DevilDog
I went to our Atwoods (farm supply store) and got to see the SpeeCo version....not even close to the quality of the Land Pride. With that beeing said, it did look like it would be ok. It's your money....:p
Troy
   / Which Hitch?? #10
My tractor is not as big as it thinks it is and when I looked for something to make it easier to hook up the TPH, two considerations, weight and being able to use implements with different pin spacing, led me to the Pats Easy Change. Since I went with Pats, I've also learned that there is a problem for some with the I Match type hitches being able to see the pins when they back up to the implement. Don't know if that is a real problem, but it's one more reason I'm glad I got what I did. I just read that Pat also offers a 30 day money back guarantee, but I don't think you'll send it back. I've already forgotten the money that they cost, but every time I use them, I'm glad I spent the money.
2006 Intellistrobe AFAD Trailer (A52377)
2006 Intellistrobe...
25 - BINDERS (A53843)
1992 Peterbilt 377 Sleeper Cab (A53473)
1992 Peterbilt 377...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
