Hello,
I am looking at HLA grapples and was wondering how big a deal the weight difference would be in everyday use. (Being up here in Canada, we're limited on our choices)
HLA has a root rake grapple and a "light" root rake grapple as well as a brush grapple.
RRGLD66 470lbs, 33-1/2" opening. HLA Attachments - Light Duty Root Rake c/w Grapple
RRG66 - 985lbs, 48-1/2" opening. HLA Attachments - Root Rake c/w Grapple
RRG78 - 1070lbs, 48-1/2" opening.
BRG72 - 865lbs - 48" wide from ground to point of grapple HLA Attachments - Brush Grapple
Primary use will be moving brush, logs, some rocks, stumps etc in the forest we have. I'm concerned that the lighter grapple might bend long before the loader would give out, but then of course, I lose the loader capacity to the weight of the grapple.
I'm not sure if I want a brush or a root, and unfortunately, I have to order sight unseen at the moment.
After speaking with HLA and another dealer, I'm leaning to towards the heavier which I believe is stronger but wanted to get opinions of those that chose a lighter or heavier grapples on their tractor and which type you went with. I've also been quoted for the Landpride SGC 1060 and 1072, but they seem to be much more expensive and equivalent to the HLA light version.
Jon
Jon
