Which Gloves for Chemicals/Fuels/Yuk/etc.?
   / Which Gloves for Chemicals/Fuels/Yuk/etc.? #1
fidowanttobe
Platinum Member
Mandan ND
Jinma 284 2007 Massey Harris 44 Special
4 different kinds, what gloves other than the disposible nitrile ones in the box do you all use for parts cleaning, herbicides/insecticides, and general purpose, "I do NOT want that on my skin" ?
Or do you mostly use the disposables only?
I do, but brake and choke cleaner turns them to slime.
So, I'm inquiring what you use for re-usable, not clumsy rubber gloves.
   / Which Gloves for Chemicals/Fuels/Yuk/etc.? #2
Since all disposable gloves seem to tear for me I use HD gloves that cleaners use to swab toilets and the like.
OK, a bit clumsy to use but then my hands remain close to acceptably clean.
I learned to give them a burst of WD40 and quick wipe so they remain fairly presentable.
From cleaning those gloves with WD40 I next sprayed my hands at some point.
What a surprise, the dirty grease simply floated off with a simple wipe of a rag and simple hand wash with regular bar of soap had them mealtime clean.
   / Which Gloves for Chemicals/Fuels/Yuk/etc.? #3
I use mostly the disposable nitrile gloves since they work in most conditions. There are a few (carb cleaner) that they don't. If only for a moment, i'll use nitrile, but only short duration. I do have a pair of the metalized barrier gloves if i'm going to be using carb cleaner much. The others I use are leather gloves for abrasion, and sometimes cotton gloves. I'll also use leather over nitrile if I need waterproof abrasion resistant. I'm also not adverse to damaging the gloves such as dunking leather in water to work under water. I prefer the nitrile because they're for fitting, but can't wear them more than 30 minutes due to sweating hands. I also have cornstarch in the shop for my hands when I have to put on a second pair.
2003 CATERPILLAR D4G (A50854)
2003 CATERPILLAR...
ONAN GENERATOR (A50854)
ONAN GENERATOR...
2014 Ford Flex SUV (A50324)
2014 Ford Flex SUV...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
2014 KALMAR 4X2 YARD DOG (A50854)
2014 KALMAR 4X2...
2020 KUBOTA RTV...
