Which Gease Where?
   / Which Gease Where? #1
Bota76er
Okaloosa CO, FL
Kubota B7610
As I was approaching 10 hours of fun /forums/images/graemlins/cool.gif, I mean work /forums/images/graemlins/wink.gif, with my new B7610 I figured I better get some grease for the FEL. I stopped in the dealer and got some JD Moly Extreme Pressure. The parts guy said they use it for eveything for all fittings on all tractors. Well it says on the tube not for high speed bearing applications. So I went to Walmart and got some Super Tech Extreme Pressure Multi-Duty Complex Hi-Temp grease (that's a mouthful). Seemed to me like this would be better for the spindles on my MMM and would work for other non-load bearing areas as well. Athough it does look like plain jane lithium grease in the three point hitch from the factory I thought the Moly would be a better choice there as well. I'm a new tractor guy so any advice steering me away from trouble would be appreciated.
In the FEL manual (LA 352) it says to also lubricate the "control lever linkage". Is this the part immediately under the shroud? Do you just oil it? I didn't see any zerk under there.
Didn't find this site until after ordering my tractor but I'm glad I found it now. Awesome stuff, especially for newbie's! I know there's a lube forum but I thought I'd start here.
   / Which Gease Where? #2
I will be awaiting the answer to this myself. I am in the same boat with my FEL. There's no shortage of grease fittings on the FEL, but none that I could see on or around the control lever/valves, and I read the same thing you did in the book.
Chris
   / Which Gease Where? #3
As for the loader valve linkage, there is no grease fitting. I use tri-flo spray lubricant. I suppose there are alot of different sprays that would work, but the tri-flo doesn't gum up with the dirt the way wd-40 does. It was also what the mechanic at my dealer recommended.
   / Which Gease Where? #4
I use moreys EP grease. The red stuff. I think amsoil has some synthetic grease
   / Which Gease Where? #5
I use Slick 50 grease on everything. Yea, I know it's kind of cashy, but I've never had a bearing failure yet so.....
I take the joystick linkage apart a couple of times a year and stuff the heaviest grease I can find in all the pivot points. I'm also going to try putting some o-rings around the pivots to help with the dreaded joystick rattle. This was pointed out on another thread and shows the wealth of knowledge available on this site!! /forums/images/graemlins/grin.gif
1998 Blaw-Knox PF 150 Paver (A52384)
1998 Blaw-Knox PF...
2006 Dodge Ram 3500 4x4 Pickup Truck (Diesel), VIN # 3D7LX38C36G220767 (A51572)
2006 Dodge Ram...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2017 FREIGHTLINER...
INSPECTION (A51572)
INSPECTION (A51572)
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2020 INTERNATIONAL...
