which gear ratio to use in my Chevy
   / which gear ratio to use in my Chevy #1
yourspectra1970
I have a 2005 Chevy Surburban 2 wheel drive 1/2 ton with a 5.3 L. motor. My truck currently has 3.42 gear ratio in it. I am towing a 32 ft travel trailer that has a empty weight of 7400 lbs. I am going to upgrade the diff. gears, however I can't decide between a 3.73 gear or a 4.10 gear ratio. The transmission is a 4L60. I would love to hear some feed back...
   / which gear ratio to use in my Chevy #2
I don't know what the exact rating is for your burb but that's a lot of weight to pull on a half ton chassis. My wife's Tahoe has a 7700 pound max towing capacity if I recall correctly so by the time you add food, water, cargo, etc that's probably going to be overloaded.
I'd consider upgrading to a 2500, if you really want to stick with the 1500 go with the 4.10 because there's no need to have a maximum loaded rig going to fast.
   / which gear ratio to use in my Chevy #3
I routinely pull 7000lb with an '04 K1500, 5.3, 4L60 and 3.73 rear. It does fine and I have never thought I would be better off with 4.10's. BUT, I don't have the wind resistance of that rolling boxcar you are thinking of pulling and with an empty weight of 7400lb, in ready to travel condition you will be substantially exceeding the towing capacity of a 1/2 ton. My situation is at or slightly over the published towing spec for my regular cab 4x4 with tow package, etc. I'd buy a truck suitable for the load you are proposing rather than painting lipstick on a pig, so to speak.
   / which gear ratio to use in my Chevy #4
Plugging these numbers into a calculator;
30" tire
0.69 OD ratio
60 mph
The 3.73 gives
2574 & 1755 rpm ( drive & OD )
The 4.10 gives
2829 & 1929 rpm.
So given the frontal area on the trailer, you should go with the 4.10's, and pull in Drive. If it were a flat deck trailer, I would drop to the 3.73's.
   / which gear ratio to use in my Chevy #5
This is a good example of why it is important to fill out your profile with information like what state/area you live in.
But to answer the question, it depends on a few things. Mainly, what are the conditions you will be towing in.
If you live in a hilly area, and plan on lots of stop and go driving, like in town, then go with the 4.10's. BUT if you live a flat area, like Kansas, and figure on 99% highway driving, go with the 3.73's for the better mileage.
   / which gear ratio to use in my Chevy #6
3.73 would be my choice. I have a friend that has the 327 with 3.73 gears in his pickup and he loves it. I have 4.10 gears in a drag car and you will burn lots of fuel with those gears. Ken Sweet
   / which gear ratio to use in my Chevy #7
If you must change gears, 4.10 without a doubt. Don't be scared by the fuel mileage comments, as most of it is hearsay. If you're going to do work, you're going to do work and you will not get some magically high mileage figures. A 4.10 isn't going to require you to go into the oil tanker business as a side line. What you will find is the mileage might be slightly lower lower overall, but with more consistent figures from empty to loaded. With the option of having an overdrive available, a 4.10 is nothing to fear. I've run this size truck as my daily driver since 1970 with 3.73, 4.10 and 4.56 axles. The 4.56 was by far the best and would give me a consistent 15mpg, empty or loaded. Granted, there are other factors involved with mpg figures. Since you have the lighter 4L60 transmission, the 4.10 would also be easier on it. I might also add that the numbers might look rather big, but the difference between a 3.42 and a 3.73 isn't much and not really worth the cost of upgrading.
The flip side of things now.
1) Your speedometer and shift points will be off. GM probably will not recalibrate it unless such an option was available as a stock item that year, and they still might not do it. Then you will have to go aftermarket.
2) It's possible that your rear carrier may not physically support either gear.
3) Depending on your supplier, the final installation might end up being noisy even if it's set up well. OEM gears are lapped and mated much better than aftermarket.
4) A slim chance you will need additional cooling.
None of which alters the reality that a 32 foot 7400lb dry weight camper will weigh more fully outfitted than the OP's vehicle is rated or designed to pull regardless of the axle ratio.
   / which gear ratio to use in my Chevy #8
I am not entirley certain, but I do believe my owners manual for my 03 chevy 1500 w/5.3L lists different towing capacities for different gears.
And I believe the newer ones are the same way as well. When looking at tow specs for new trucks, they give a listing of xxxx lbs if you have lower gears (higher #). And then they give a lower listing for the higher gears(lower #)
Now I dont know if their are any other differences, but if not, the MFG's are giving higher tow ratings if you have better gears. That is all the OP is trying to do.
Now that still doesnt make it "legal" on paper. Because all law enforcemt goes by is what the stickers on the truck say. But in reality, what is the difference.
It's kinda like putting a 3/4 ton frame and axles under a 1/2 ton truck. In all reality you have a 3/4 ton truck capabilities, but "LEGALLY"are still limited to 1/2 ton payloads.
Fords website is the best I can find at the moment. But notice that the lower gears typically have higher tow ratings.
2011 Ford F-150 | View Towing Specifications | Ford.com
   / which gear ratio to use in my Chevy #9
You're 100% correct! I should have emphasized your original statement and said to just throw away the lipstick. The proper truck is simply the BEST answer.
Thanks for clarifying. I really couldn't understand what you were getting at in post #7.
   / which gear ratio to use in my Chevy #10
What you say is true, but chances are that with one of those other higher gears, he still isn't going to bring the truck up to the proper GCWR.
My #7 post was mainly to list some pros and cons on the gear change if he absolutely decided that he "MUST" make a change.
Well, its 2wd so that is a plus.
Question to the OP: What does the owners manual rate the towing capacity at???
I do believe on my 03 1500 4x4 it is around 7800lbs, but I can't rember for sure.
Yours being 2wd and newer, I would think it may be a tad more.
2012 FORD F450 SERVICE TRUCK (A53426)
2012 FORD F450...
LMC LOT NUMBER 237 (A53084)
LMC LOT NUMBER 237...
20" Sea Container (A47384)
20" Sea Container...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2025 K1119 UNUSED Metal Carport (A53117)
2025 K1119 UNUSED...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
