Which dirt scoop?
   / Which dirt scoop? #1
normde2001
Elite Member
I am looking to buy a dirt scoop for my YM2000B and am not sure whether to get a 24" or 30". A dealer recommended a 24", but I see several guys are using 30" on 2000's and even 1700's. Do they work satisfactorily or are they too heavy when loaded for a 2wd?
   / Which dirt scoop? #2
I'd say get the big one. Unless you are trying to pick up a boulder, you aren't likely to put more than your tractor can lift in it. In fact, even if you have 1/3 of a large rock sticking out, you'll still be able to lift it if you have enough weight on the front end. (This is based on a 21HP Kubota.) Loose material tends to fall out, so you'll appreciate the extra mulch or sand you can carry with the larger scoop.
   / Which dirt scoop? #3
Go for the 30 inch scoop. I had one on my YM2000. It handled it very well with front suitcase weights.
   / Which dirt scoop? #4
Make sure your arms will lift high enough to dump the three ft scoop. I have read in posts on the old site that some scoops would not dump because the arms would not lift high enough.
HILLBILLYMAN
   / Which dirt scoop? #5
I have a 30" from Tractor Supply. Cost $239. Well built.
I have a small Kubota and it works just fine.
   / Which dirt scoop? #6
Get the 30". I have a 30" scoop for my 1510. It works well, but could use a little more weight on the front end. When I fill it to the point of falling over the sides, with wet dirt, the front end wants to lift. If I drive in reverse to where I am taking the load, it works fine. If you are not in a hurry, consider buying a used scoop. You will probably pay 1/3 to 1/2 the price of a new one. All you"ll most likely give up buying a well built used scoop, is some paint may be rubbed off.
   / Which dirt scoop? #7
Yep! I have a 1401d--and did have a 24" scoop but couldn't lift it high enough to dump...
Unfortunately, I returned the scoop before posting my predicament to you guys on the old Yahoo group. If I had been willing to do a little rigging, I could've made it work! I'm still kicking myself for that one/w3tcompact/icons/mad.gif, especially after reading how useful those scoops can be.
tonyw
   / Which dirt scoop? #8
I'm the guy with the 1700 and a 30" scoop.. The tractor is strong enough to lift more dirt than the scoop can hold. I had to add about 200lbs to my front to counter ballance.
Works great. Also, I did change out my lower lift arms to longer off the shelf ones from tractor supply ( ford 8n??).. but works great.
Soundguy
   / Which dirt scoop?
Actually, Soundguy, I did sneak a peek at your profile. That's what prompted the question. I may take the dealer's suggestion and get the 24" just to be sure it will lift high enough to dump and not have the weight problem.
3111 (A49339)
3111 (A49339)
2016 John Deere R4030 Sprayer, 120ft Boom, 800 Gal Poly Tank, Hydraulic Traction Control (A48561)
2016 John Deere...
Pallet Forks (A49339)
New Skid Steer Root Rake 31'' (A48289)
New Skid Steer...
(7) Front Tractor Weights (A46502)
(7) Front Tractor...
2005 Ford F-150 Ext. Cab Pickup Truck (A46684)
2005 Ford F-150...
