Chains Which Chains?
   / Which Chains? #1
Grande
Southern Vermont
Kubota L3010HST
Hi all,
I'm about to purchase chains (from tirechain.com) for my L3010 and can't decide between duo-grip or duo-grip with v-bars for added traction. Here in icy southern Vermont it does get a little slimey sometimes. Is simply having chains adequate or is the extra $$$ worth it for v-bars? Whaddaya think?
Thanks,
Jon P
   / Which Chains? #2
Hi,
I don't know actually...
But I do know that you will only do it once! Too expensive to repeat the purchase.
Generally, if I am not sure which way to go in a case like this, I will go the "overkill" route, rather than wish I had later...
In my case I only had 2 link as the option for my B2910. I lusted for a L3010 when I saw the chain options available for that model. /w3tcompact/icons/smile.gif Too late now...I bought the B2910...
Good luck...in your decision. I am sure others here will give you some great specific advice.
Bill in Pgh, PA
   / Which Chains? #3
What is the area u are plowing?
Gravel, asphalt or ????
Gravel or dirt or mud get the best u can(V bars).
Concrete or asphalt go more conservative or
take chance on marking the surface.
   / Which Chains? #4
Grande -- I had ordinary chains on my B1750 which worked just fine...until they ran into that slippery Vermont ice! /w3tcompact/icons/shocked.gif With the L3010 I went with the Norse ice chains and absolutely love them! Under the right conditions Clementine can still slip a bit, but not so much that she gets into trouble. I have the v-bar chains on my ATV, and they do just as well on ice.
Any of the aggressive chains will damage pavement, however.
Pete
   / Which Chains?
Gents,
Thanks for the input. It sounds like V-bars are the right choice for my application. The only pavement I'll ever see will be the in the garage and that I can deal with. The uneven terrain is dirt gravel and often, ice.
Jon
   / Which Chains? #6
I'd also go with the V bars as that is what 's on mine. My tires are much smaller diameter and on hard packed surface the V bars can ride pretty rough.
They will exspecially have an advantage on side slopes.
Egon
   / Which Chains? #7
Grande, I just installed Duo-grip chains from Tirechain.com on Saturday. The chains really fit very well, and the amount of difference in traction was quite amazing. I was able to plow up a hill in 2wd, with the diff. locked, that I was having trouble climbing in 4wd, not plowing. I haven't had a chance to try them on ice, yet, but I would think if you have constant, heavy ice, the v-bars would be the only way to go. Oh, I have an L3010 with R4 tires.
   / Which Chains?
Elmo,
Thanks for the advice. I think I'll do the same. Are you plowing with your tractor? If so, by what method, i.e., bucket, blower, blade, etc.?
Grande
   / Which Chains? #9
Grande, I have a Landpride RBT1584- 7 ft. rear blade that I plow with, I use the ft. bucket to pile snow in tight areas. I'm collecting parts to build a variation of the overpriced Kubota ft. blade setup for future use.
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
NISSAN 50 STRAIGHT MAST FORKLIFT (A51242)
NISSAN 50 STRAIGHT...
UNUSED FUTURE MINI EXCAVATOR HYD THUMB (A51244)
UNUSED FUTURE MINI...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
