Which BH for CK30hst
   / Which BH for CK30hst #1
VictorW
Veteran Member
Erie, Pennsylvania
Kioti CK30HST
After using this tractor with FEL, I find more things to do and now would like to get a BH.
Kioti's site recommends their model KB2375 or KB2376. The specs. are the same. Is there a difference? Also saw the Rhino 75. From Rhino's site, it looks like it's the same as the Kioti's brand and the specs. are almost the same. Does Rhino make them for Kioti? Maybe there is another brand to consider.
Any suggestions or recommendations are greatly appreciated.
   / Which BH for CK30hst #2
They are the same backhoe, just the mounting is different. the 2375 is the traditional sub frame, and the 2376 is a quick attach with 4 pins in the rear, takes about 4 minutes to remove , and 6-7 to install /forums/images/graemlins/smile.gif
   / Which BH for CK30hst #3
I've heard people say to only go with a sub-frame type so you don't snap your tractor in half. Is it the same for the Kiotis?
   / Which BH for CK30hst #4
</font><font color="blue" class="small">( I've heard people say to only go with a sub-frame type so you don't snap your tractor in half. Is it the same for the Kiotis? )</font>
What Kioti recommends against, and does not support are 3 point hitch backhoes. Both the KB2376 and KB2375 are subframe backhoes, with just different means of attachment. The 4 point hookup actually has a couple of hooks at the bottom that one sets the BH into, then the top is moved into position and pinned in. Very sturdy hookup, but both are mounted to subframes that meet and connect with the loader near the front of the tractor which spreads the stress over a larger area than a 3 point hookup does.
John
   / Which BH for CK30hst #5
The KB2376 is for the Lk3053xstlb only.
That will not fit the ck series.
I would go with the Rhino 75 backhoe.
   / Which BH for CK30hst #6
</font><font color="blue" class="small">( Also saw the Rhino 75. From Rhino's site, it looks like it's the same as the Kioti's brand and the specs. are almost the same. Does Rhino make them for Kioti? )</font>
SMC/Rhino used to supply backhoes for Kioti, but not any more.
The Rhino and Kioti hoes are not the same hoe.
I second the recommendation for the Rhino 75.
   / Which BH for CK30hst #7
</font><font color="blue" class="small">( The KB2376 is for the Lk3053xstlb only.
I would go with the Rhino 75 backhoe. )</font>
I know that's the way it's supposed to be, but member bluecarpenter PM'd me and was referring to his backhoe hookup which was just like the 2376, but said it was the 2375.
This is part of what he wrote:
</font><font color="blue" class="small">( I know the hook up on the subframe is different. the one that i tried last fall had 2 pins at the back. it slid into a guide towards the middle of the tractor. a poor design in that when using bh arm the only thing that keep it from moving were the 2 pins at the back.
Mine has 2 hooks at the back end that are facing back. under axel. back the tractor up till is stops at hooks then raise boom and the front of the subframe pivots up and hooks into 2 U shaped pieces facing down. then install 2 pins under neath subframe. a defininate positive lock.)</font>
John
I appreciate your and wallace's advise along with everyone else. It's hard to know which brand to consider. Looking at pictures and specs. doesn't tell you which is better. I've used a few different BH's over the years but they were only borrowed for a short time.
Nothing better than TBN and its members.
Thanks again
   / Which BH for CK30hst #9
John
I think bluecarpenter has the Rhino subframe but the Kioti hoe. I spoke with him on the phone several days ago and he described what he had.
   / Which BH for CK30hst #10
victor,
I but a Rhino 85 on my Ck30hst. I love it. Kioti don't support this configuration.
2016 CATERPILLAR 325FL EXCAVATOR (A51242)
2016 CATERPILLAR...
Kubota 29" Backhoe Bucket (A50774)
Kubota 29" Backhoe...
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
2016 Chrysler 200 Sedan (A50324)
2016 Chrysler 200...
