brettmarty
Hey fellas,
I am tractor shopping and I am giving LS a very serious consideration. I, like many posts in the past, was suspect of the LS brand being so much CHEAPER! But after hearing alot of your testimonies and alot of research it sure seems like a great tractor.
One of my largest concerns is the power of the backhoe. I will be doing alot of road work and trenching in rough rocky soil. At a certain point I know there will be rocks that I just cant dig with any tractor-backhoe and that's when you call in the mini-ex, however the more I can do in house the better.
I'm currently looking at the R3039, R4041, and the R4047. Beyond extra digging capacity I really doubt I need more horsepower than the 39. The stock backhoes that would best fit these tractors are as follows: 39=LB2100(digging force 2679#); 41and47=LB2101 (digging force 2679#). Oddly enough the the backhoe for the 3038 has a digging force of 2800#.
Now there is another option; put a larger backhoe on the tractor. LS makes a 3100 and 3500 series backhoe. The 3500 is for the U series and 50 HP tractors however my dealer thinks that the 3100 would fit on either the 41 or 47 no problem. That would up the digging force to 3750#.
My only experience with backhoes was operating a micro excavator (TB100) with a digging force of 2250# but the thing only weighed 1000# which was the limiting factor in most cases (the rear end would just lift in the air). These LS tractors will weigh alot more though. So the bottom line is should I go for the bigger backhoe. Would a R41 be able to handle a 3100 series backhoe, and more important than that do I even need the extra 1000# of digging force. What are your guys' experience with backhoes on these units.
Cheers,
Brett
Cheers,
Brett
