Buying Advice Which ATV sprayer to get
   / Which ATV sprayer to get #1
KenB2920
Veteran Member
Almont, Mi
Kubota L5240HSTC
Looking to get a liquid sprayer for ATV with BOOM for spot spraying.
I think I'd like to stay between 15-30 gallons. My main concern is leaks, functionality without clogs. I had a 2 gallon pump and I spent more time fixing and replacing tips rings seals etc than actually using the darn thing.
I will be using this to spot spray my pond, fertilize areas of the lawn, herbicides and whatever else liquid I can use it for. I will probably use this once a month or so.
I've read a tad about these with pumps burning out, different leaks etc. I just want a decent quality one. What are your suggestions, experiences etc.
A spray wand is a must.
   / Which ATV sprayer to get #2
There are lots of sprayers out there, and I am sure others will chime in as to what is the best sprayer. I would avoid boom-less sprayers. They allow the chemicals to drift far more than a boom sprayer. A droplet can travel a long distance away from where it was sprayed if it is the wrong size, a boom sprayer provides better consistency on droplet size. A boom sprayer allows more control over droplet size reducing drift. Also a boom sprayer will provide coverage that is more consistent than a boom-less sprayer.
Depending on your use these disadvantages might not be as important.
Advantages of boom-less sprayers is that they are less expensive to purchase, and there is no boom to break off on trees.
   / Which ATV sprayer to get #3
Skip the one from Tractor Supply Co. I picked up a 25 gallon model from them last year for spot spraying in the UTV. Hose sprang a big leak during the first use and the regulator doesn't cut the pump off till 80 psi (non-adjustable). That's way too high a pressure to consider rigging up any type of boom for. Too high for spot spraying in my opinion too, but I guess that's open for debate.
Ok, how do the TSC and FFH etc compare to the northstar from northern tool.
It seems all of these are vary close visually but it seems the pumps all differ is GPM ....
Is a 5.5 GPM to hi of a rate?
I really am attracted the the 26 gallon North Star boom less. I seem to like this better than the 5.5gpm model. I like not having to take the ball off my hitch and attach a separate piece.
I also think with the hose on this boom less model I could simply make my own boom out of PVC.
What I do like about the 5.5 model is you can shut one side off.
With the 2.2gpm can the Nozzle be turned to only spray one side?
   / Which ATV sprayer to get #5
I purchased a 30 gallon sprayer from TSC about 5 years ago. I have it mounted on our 4 wheeler. I rigged up a dry boom and use 3 nozzles
across the back to spray weed killer. If I remember correctly the pressure is set at 40psi. The higher pressure pumps are better suited for spraying trees such as in an orchard. I don't remember the flow but it would be nice to have a pressure adjustment like the larger sprayers.
One can be rigged up but most inexpensive tanks don't have connector for a return or agitator. My biggest gripe is the line that comes out of the tank to the pump has a little screen in the connector. If it gets clogged then to remove the screen the chemical runs out until you cap off the line. It really needs a shutoff valve. We use this to spray several tanks every day so we are sure to use clean water and clean the screen every other tank when it is empty. We also put in a little bleach everyday to cut down on algae.
   / Which ATV sprayer to get #6
I have a Fimco 30 gal sprayer from TSC on my ATV. It has worked well for about 10 years. I have broken the hose several times by getting it caught under a wheel, but that is my fault. The 12v electric pump is adjustable. There is a phillips screw in the center of the pressure switch (between the electrical connectors) on the pump that will adjust the pressure at which it will cut off.
   / Which ATV sprayer to get #7
I bought a FIMCO 15 gallon spot sprayer from TSC that I'm well pleased with. The addition of a boomless nozzle and some fittings for another $25 or so and it makes a decent broadcaster sprayer too. Little bit on the small side at 15 gallons but refills aren't hard...
   / Which ATV sprayer to get #8
I bought the 26 gal. North Star sprayer from Northern Tool and I am very satisfied with it. Mine does a wierd thing though. When the pressure drops as the tank gets low and the pump cavitates the rear boom starts spraying. I have the valve set for the wand but if pressure is low the boom comes on. Not good when spraying glyphosphte. That should be a straight cut off valve that controls which spray is on so I can't figure this little problem out. Other than that it's good.
Ok good to know. I just pressed the submit button and also purchased the northstar 26 gallon sprayer. Looks like all the tanks are generic. They clay to be thicker plastic but I can't find specs on the thicknesses. They seem to have the best pump and I wasn't able to determine if the other brands pumps were on demand or constant.
It should be here in a few days and I have many uses for it. What I hope is that I can spray in one direction with the boom. When I circle the pond id like to just spray to the right or left. I may try and water the garden the way too.
I look forward to weed control. I also look forward to taking my 2 gallon pump sprayer and punting it to the curb. What a PIA it has been.
Oh well. Thanks for all the help. I will leave a review here in time.
   / Which ATV sprayer to get #10
When you assemble it make sure you don't over tighten the plastic hose nipple that threads into the pump outlet. I broke mine. Read the instructions and it tells you how much to tighten it. I think you can rotate the sprayer head on the boom so it would only spray to one side but the coverage would be uneven with more right below and less the farther out from the boom.
JOHN DEERE 6115D MFWD FARM TRACTOR, S/N 061374, CAB, HOUR METER READS 5250 HRS (A40517)
JOHN DEERE 6115D...
2013 Kobelco SK210LC Excavator (A40488)
2013 Kobelco...
John Deere Z355E Zero Turn Mower (A44500)
John Deere Z355E...
7' WORK BENCH, 35 DRAWERS (UNUSED) (A40519)
7' WORK BENCH, 35...
2015 PETERBILT 367 SLEEPER (A45046)
2015 PETERBILT 367...
72" Brush Fox Grapple (A40784)
72" Brush Fox...
