Buying Advice which 15xx/16xx models have clutchless forward/neutral/reverse?
   / which 15xx/16xx models have clutchless forward/neutral/reverse? #1
thebonepile
South Dakota
Deutz 7120 from junkyard
I am interested in a tractor about the size of a MF 1540. I am definitely looking more for a geared tractor rather than a hydro. (hate the whine) But I have a special needs kid who could use a left hand reverser as long as you dont have to depress the clutch. I went to the AGCO section and of the geared transmission choices for the 1500 series none seem to have the clutchless option.... I have no problems with a used one, is this something that isnt offered anymore?
From browsing utube and tractorhouse I am assuming a power shuttle will do this , am I correct?
Thanks in advance
   / which 15xx/16xx models have clutchless forward/neutral/reverse? #2
The old 1533, 1540 tractors had it as an option. The current production 1533, 1540 don't. You would have to step to a 1635 or 1643 to get a power shuttle in a new machine. The current 1533 & 1540 are Standard shuttle as a more value based machine.
   / which 15xx/16xx models have clutchless forward/neutral/reverse? #3
Power Shuttle also gives you another range to have 12 speeds rather than 8 with the Standard Shuttle.
   / which 15xx/16xx models have clutchless forward/neutral/reverse? #4
I have a 1648 cab with the DynaQPS systems. So far it works well and I am very pleased with it. With the recent snow storms that came through after christmas i was able to get some seat time and found that you can run most of the time without depressing the clutch.
   / which 15xx/16xx models have clutchless forward/neutral/reverse? #5
I have had three Hydro tractors. The last one for fourteen years and never had any whine. I hear this statement lots of times.
   / which 15xx/16xx models have clutchless forward/neutral/reverse? #6
Powershuttle and DynaQPS are clutchles like you want. The HST in the 1600 series is noisy, especially if you get a cab.
   / which 15xx/16xx models have clutchless forward/neutral/reverse? #7
When I purchased my 1532 , the brochure said you could shift the syncroshuttle shuttleshift w/o clutch . On u tube their is a video comparrision NH MF Kubota showing MF doing this . In saying all of this I always use the clutch . Hope this info helps .
   / which 15xx/16xx models have clutchless forward/neutral/reverse? #8
You CAN NOT shift the 1532 & 1529 Syncro Shuttle without the clutch. Not without doing damage anyway. The videos and brochures I've seen state the machine can be Shuttled without coming to a stop, while depressing the clutch. That's where the syncro comes in. They aren't a power shuttle/power reverse transmission.
   / which 15xx/16xx models have clutchless forward/neutral/reverse? #9
As I said in my post , I always use clutch , and my manual says this too . MF video and brochure is not clear on that , or at least wasn't when I purchased . Sorry , for your angry face:)
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53472)
2006 Magnolia Dry...
JOHN DEERE 4730 LOT NUMBER 258 (A53084)
JOHN DEERE 4730...
8065 (A51572)
8065 (A51572)
2015 PETERBILT 367 SLEEPER (A52576)
2015 PETERBILT 367...
Ryobi Weedeater (A51573)
Ryobi Weedeater...
Ryobi Sliding Miter Saw (A51573)
Ryobi Sliding...
