Where's a good location for Hydraulic Guage
   / Where's a good location for Hydraulic Guage #1
Bigbear
Central Indiana
Jepe 354
Where\'s a good location for Hydraulic Guage
I would like to install a gauge for the hydraulics so I can monitor what's going on. Would you put it right after the pump, or somewhere on the loader or backhoe. I feel like I could better judge the rpm's while running the backhoe if this gauge was in the system. BEAR
   / Where's a good location for Hydraulic Guage #2
Re: Where\'s a good location for Hydraulic Guage
A pressure gauge is going to tell you very little. The typical open center system will develop nearly the same pressure just off idle that it will at WOT. And the actual pressure developed is directly related to the work being performed, not ERPM. But if you wish, plumb the pressure gauge anywhere between the pump and control valve you wish to monitor. A flow meter will give flow rates which are directly related to open center system pump (engine) speed. All pump output will have to be directed through this device. An inexpensive analog 30GPM flow meter will run about $180. There may be lower capacity units out there at a lesser cost.
20" Sea Container (A47384)
20" Sea Container...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2006 Dodge Ram 3500 4x4 Pickup Truck (Diesel), VIN # 3D7LX38C36G220767 (A51572)
2006 Dodge Ram...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52748)
Ditch Witch 6510A...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
