Where to replace Hydraulic Fluid
   / Where to replace Hydraulic Fluid #1
jadire
JD 2940
I have a JD 2940 and I took off the draft link to change it. Took off the bushing and the spring that holds it on. What I didnt know is that the hydraulic fluid is in there. now, my hydraulic fluid is drained out on the pto side.
I'm not sure where to fill it back up after I change out the draft link...and I am not sure if I need to do additional steps to ensure the hydraulic function.
Please help...
   / Where to replace Hydraulic Fluid #2
The dipstick should be behind your left heel as you sit on the tractor, it is threaded in the tube. Fill cap is at the rear of the tractor above the top link mount. About a 2" diameter cap with a scalloped perimeter. This cap is also threaded. One fill point for the transmission, rear axles and hydraulics.
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
BUSH HOG 7007 LOT NUMBER 115 (A53084)
BUSH HOG 7007 LOT...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
Electric Mobility Scooter (A51694)
Electric Mobility...
2021 FORD TRANSIT 250 CARGO VAN (A52576)
2021 FORD TRANSIT...
