*** Where to loop chaint to pull a 3910 from the front? ***
   / *** Where to loop chaint to pull a 3910 from the front? *** #1
CCWKen
Veteran Member
South Texas, USA
Ford-3910, JD-420C, Kenbota-Custom, IH-2606
HELP! :)
Just got the Ford stuck in a mud hole while backing up. I need to try and pull it out with a JD420C (yeah, I know) so I need to know where to run the chain in the front. The rear is not accessible. I thought about running the chain up through the front axle bracket, just behind the axle, over the top of the axle bolt/bushing then back down the other side so that the chain will pull from the bottom of the bracket. I don't feel comfortable just pulling on the axle.
TIA, Ken
   / *** Where to loop chaint to pull a 3910 from the front? *** #2
Assuming you don't have a weight brackets or brush guard?
   / *** Where to loop chaint to pull a 3910 from the front? *** #3
I think you have it covered. Maybe use a fabric sling in between to reduce shock. I use a long heavy hydraulic cylinder with shackles at each end to get myself unstuck. Plug it into the remotes. It is slow but unstopable and I don't need another person around.
Just got back in. Pulled with the chain as I mentioned. Worked great. Had to get my sister to dump the clutch and drive the tractor while I pulled with the dozer. That was her first time in a tractor seat. She did good and didn't run over me. :)
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
New Long Forks (A53002)
New Long Forks...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2008 KENWORTH T-300 LUBE TRUCK (A52472)
2008 KENWORTH...
