where to go in connecticut for service
   / where to go in connecticut for service #1
edkinct
NE Connecticut
CK20S HST
Hello,
I have a ck20s hst and I have developed what i believe is a hydraulic fluid leak. Its on the same side as the 3pt hitch control and seems to be above the filter that is under the 3pt hitch control. I say that because the fluid is on top of that filter and on the hoses above that filter. I hope this makes sense.
Unfortunately the dealer I bought my tractor from is no longer in business and the closest Kioti dealer is about 30 miles away in the neighboring state.
I live in Scotland, ct. and have quite a few other dealers in the area. Just wanted to know where others in connecticut go for service.
ED
   / where to go in connecticut for service #2
I had a leak that was dripping down underneath. Had to take seat off and it was a connection that needed to be tighened up. Not sure if this helps.
   / where to go in connecticut for service #3
I have had my CK 20 hst for a year and a half and have not had any service required, did the 50 hour myself. I have heard good things about Campbell in Bridgewater, CT, but have not used them. Priced my tractor from them but they were high priced.
As someone suggested, I would do some searching myself, the leak is probably just a loose fitting.
Great opportunity for a business of servicing tractors on site, there must be an out of work mechanic who could travel around in his pickup truck and administer to the sick tractors, just like the big animal veterinarians.
thanks for the suggestions, I will have to do some poking around and see what I find.
Nate & Gill,
thanks for the suggestion, I took the seat off last night, and sure enough, it was a loose fitting that I just tightened up.
Once again Thanks
ED
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
KJ 11'x19' Single Steel Carport (A50121)
KJ 11'x19' Single...
Unused 2025 CFG H15 Mini Excavator (A50322)
Unused 2025 CFG...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
12in Excavator Bucket (A50322)
12in Excavator...
2014 Peterbilt 384 T/A Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
