Where to get large diameter PVC pipe or tubing
   / Where to get large diameter PVC pipe or tubing #1
Mosey
Veteran Member
Conifer, Colorado
2000 New Holland TC29D with 7308 FEL, and top & tilt. 1950 John Deere B. 1940 Farmall A.
I have this crazy idea to try to make a water slide for the kids. I won’t need a ladder or anything, since I have a 15 to 20 degree hill available right in the back yard (they're only 6 years old, so they don't need to go too fast). My plan is to put an inflatable pool at the end for them to splash into and use a small pump to pump the water from the pool to the top of the slide. The hard part, and probably expensive part, is figuring out what to make the slide out of. The only idea I have so far is to use some kind of large diameter pipe or tubing, at least 18 inches in diameter and smooth on the inside, and cutting it in half to get a U shaped slide.
How big do they make PVC pipe? Any other ideas for what to make the slide out of?
   / Where to get large diameter PVC pipe or tubing #2
Since the lil munchers are so young, why not a Fisher-Price plactic sliding board or a plastic one from a swing set at Toys R' Us. De-burring and rounding the edges of the PVC might be a pain in the behind, and if you miss a spot could be a pain in the behind for the lil ones too.
   / Where to get large diameter PVC pipe or tubing #3
Danny, you can get PVC culvert pipe pretty big but make sure you get the double wall stuff. That corrugated single wall could make for a painful ride down /w3tcompact/icons/wink.gif
I always see a lot of the stuff at Carter Lumber in our area. Also try a plumbing supply house. Ours didn't carry it but directed me to a place that does /w3tcompact/icons/smile.gif
   / Where to get large diameter PVC pipe or tubing #4
Wow!!! Very ambitious!! My kids get a much simpler "removable" version kind of like the <A target="_blank" HREF=http://www.qualityrecreation.com/w90072.html>slip 'n slide</A>. Basically, just some heavy duty poly cut to about 3' wide pinned down at the edges with landscape pins. Works great with the water flowing down it....and at the end of the day it gets folded up and the grass is barely dented! /w3tcompact/icons/smile.gif
Kevin
I got them a slip and slide last year and it tore apart when they slammed into the end of it. Of course, I set it up so they could slide down the little slide on their swing set and get up more speed!
   / Where to get large diameter PVC pipe or tubing #6
Make sure the pipe is UV stabilized. I picked up a leftover piece of PVC pipe a number of years ago with the same idea. As things sometimes go around here, the pipe sat for a year or so without any activity on the project. One day I noticed the pipe had split. Whe PVC pipe breaks, it leaves some nasty edges...........chim
   / Where to get large diameter PVC pipe or tubing #7
form trough with clean fill sand and line it with 6 mil plastic or pvc shower stall liner sheeting in 5' widths and fix soaker hose to crest to keep slide wet
   / Where to get large diameter PVC pipe or tubing #8
Mosey,
Oh ya...I'm not saying buy them a slip n' slide...they are too cheap!!! My parents bought the "grandkids" a slip n' slide to use at Grampa and Gramma's house. I think it lasted about 1 1/2 hours /w3tcompact/icons/crazy.gif. Then we made one out of very heavy duty poly. Still using it.
Kevin
   / Where to get large diameter PVC pipe or tubing #9
Mosey,
Have you thought about pond liner or the roll rubber roofing? Seems that stuff should be though enough to slide on without tearing up, and would be easier to dispose of after the kids get too big to play with it anymore.
SHF
   / Where to get large diameter PVC pipe or tubing #10
Another possibility would be talking to some swimming pool companies about old or faulty vinyl pool liners. I know this 'cause we are in the process of replacing ours again - second time in three years - the first one lasted 18 years and was replaced two summers ago. Now the company (bless them) is replacing this two year old one under warranty because a seam was not finished properly - the removed liner works for decorative pond liner, waterproofing around the end of a culvert, lining a cracked birdbath, etc, etc.
Bob
ATV (A44572)
ATV (A44572)
2007 Ford Mustang (A44501)
2007 Ford Mustang...
2012 INTERNATIONAL 4300 CAB AND CHASSIS (A43004)
2012 INTERNATIONAL...
2006 INTERNATIONAL PAYSTAR 5900I (A45333)
2006 INTERNATIONAL...
2016 Freightliner M2 106 Palfinger Epsilon Forestry Grapple Truck (A42742)
2016 Freightliner...
2013 FREIGHTLINER CORONADO 122 SD (A45333)
2013 FREIGHTLINER...
