Where to find PTO gearbox.
   / Where to find PTO gearbox. #1
Pete Judd
Veteran Member
The Thin Gravy Ranch in The wet PNW
Yanmar 186d, JD 314
Just started a project, and need a right angle pto driven gearbox like those on a brush hog. Standard male spline on the input to a keyed shaft on the output, not even sure what to call this gearbox to google it.
   / Where to find PTO gearbox. #3
ROTARY MOWER PARTS - Agri Supply
Try this link or google rotary cutter gearbox, snow blower gearbox, post hole digger gearbox and similar
   / Where to find PTO gearbox. #4
ditto surplus centr. probably one of the better priced places around. stock changes rapidly so if you find something you like.. get it.
soundguy
Surplus center did not have any with the 1 3/8 6 spline input shaft, The AG supply one for 119 bucks, is what i am considering right now, but just got a line on a local used stuff place that might have something that will work.
   / Where to find PTO gearbox. #6
A lot of farm machinery use them including manure spreaders, choppers, etc, etc. The trouble is, with the price of junk, they're getting scarce. I bought a nice reversible one about 3 yrs ago for $15.
   / Where to find PTO gearbox. #7
if they had round input shafts you can get round to splined adapters..
soundguy
   / Where to find PTO gearbox. #9
you will want to watch the HP rating of the box,
and I am going to suggest that if you think the machine will use 15 hp put a 30hp rated unit on it at least,
I one time figured out what I needed on a machine one time, and put on the 30hp rated box as that was all the tractor that originally ran the unit was,(from factory) figured it would be OK, I used a larger tractor on the unit and burnt up the gear box and the U joints, in a hurry,
Ordered the agi supply gearbox, will be here in a week or two, will update, after the next welding spree.
SCRAP METAL AND STANDS (A45046)
SCRAP METAL AND...
2025 72in Hydraulic Dual Cylinder Grapple Skid Steer Attachment (A44571)
2025 72in...
Chery 14' Bi-Parting Iron Gate (A44502)
Chery 14'...
(2) FORD TRAILER HITCHES (A45046)
(2) FORD TRAILER...
Palfinger PSC 4016 4,000lb Service Crane (A44571)
Palfinger PSC 4016...
TMG-ALP03 Hydraulic Pump Power Unit For Auto Lift (A42745)
TMG-ALP03...
