Where to connect lift rods to lower links on Kubota B7100
   / Where to connect lift rods to lower links on Kubota B7100 #1
Wilburn Cox
Bronze Member
Stephenville Texas
Kubota B7100
On a Kubota B7100 HST there are 2 holes on the lower link arms where the lift rods may be connected. Which hole should the lift rod be connected to? Does it make a difference in the operation of the 3 PT lowering and lifting limits?
Thanks in advance for any advice.
Red Cox
   / Where to connect lift rods to lower links on Kubota B7100 #2
The farther the lift rod is connected toward the ends, the more weight it will lift but the arc of the arms is less. The lift arms won't go as high as they would if the lift arms were attached back toward the tractor rear end. In the forward hole (toward the tractor) the arms will raise higher, but have less weight capacity.
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
2009 Chevrolet Cobalt Sedan (A50324)
2009 Chevrolet...
2011 Ford Explorer Limited AWD SUV (A50324)
2011 Ford Explorer...
1996 Elgin Pelican Series S Street Sweeper (A50322)
1996 Elgin Pelican...
2016 Dodge Caravan Van (A50324)
2016 Dodge Caravan...
