You could make one out of concrete, buy one of the tractor supply 3pt drawbars, to get the pins and the start to bolt some angle iron to the predrilled holes in the drawbar, that come up to form your top link connection. The most metalworking you have to do is drill some holes in the angle iron, you can use a hand drill for that. Put everything in a box for to fill with concrete, when it sets up, remove the wooden forms and now you have a concrete weight with your 3pt connections cast into the concrete.
Not a lot of work, or money. I am not sure which of these bars you need. depending on your size. I would use some 2 inch angle for the uprights, and drill your holes and get the cross pin for the top link.
CountyLine® Cross Drawbar, Category 1, 3/4 in. dia. - Tractor Supply Online Store
CountyLine® Cross Drawbar, Category 0 with Category 1 Pins - Tractor Supply Online Store
James K0UA
Man that's really wierd we were thinking the same thing at the same time
Sent from my LGL35G using TractorByNet
James K0UA
Well now, there you go, a complete solution, minus a little plywood or OSB, some used motor oil, a few bolts and nuts and 4 80 lb. bags of sackcrete. Heck it don't get a whole lot easier than that.
James K0UA
