Where is POWER STEERING FLUID at to add on my 165 Diesel.
   / Where is POWER STEERING FLUID at to add on my 165 Diesel. #1
Fatdaddy
Jackson Tenn
Kubota
I have looked it over, if you got a picture of where it is please send my way..
David
Tennessee
I found it I THINK, under the front cover I followed the hose to the pump..
   / Where is POWER STEERING FLUID at to add on my 165 Diesel. #3
I don't know for a 165, but here's something to check and consider. The tractors that I have with power steering (Kubota & John Deere) use a hydraulic cylinder to do the steering. That means that the hydraulic system that runs the loader, 3 PH and anything else you have attached via hydraulics also runs the power steering. The Kubota L235 uses a single pump and runs everything with that. The JD uses a double pump and one is dedicated to the steering, the other pump runs everything else.
   / Where is POWER STEERING FLUID at to add on my 165 Diesel. #4
I think 3Ts is right
KONE CRANES SMV-25-1200 HEAVY LIFT FORKLIFT (A52472)
KONE CRANES...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
CAT Skid Steer (A50322)
CAT Skid Steer...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
