Brian--thanks, I looked at the grapple on web, looks good. Now to find out how much to ship. Also thanks for grapple technique--will try it when I get grapple. Some of the roots are tough for the FEL to get up so I just leave them. Hope they will die when I burn the property off. If they come back, I will have to figure out a better way to control them.
Larry--I will check the seat a 3rd time. Will probably take it off just to make sure but I think it is currently as far away from the connects as possible. Even if it can be adjusted more away from the remotes (don't believe it can), then the seat is fairly close to the controls which presents a problem in comfortably using the controls. And for larger folks may end up being downright difficult. I think the real fix is to prob move the seat up a few inches or shorten the hyd remotes (if it can be done) on the tractor or combination of both. I am 5' 11" and the seat height is about right now but I could prob deal with 1-2 inches higher so that the angled seat back clears the hyd connections. Just sitting there I don't think it makes contact but when someone is sitting in the seat, it leans back into the connectors and a jolt or two and they disconnect.
Mahindra called me on the phone yesterday. I am going to send them some pics and see what they say. I must say that they have been very quick to act so far and I think they will resolve the issue. So far I am very happy with their response and that is from the company. You don't get this kind of response from very many other companies.
Thanks for the info on the oil drain. I will see if I can find it. Sure would be nice if they color coded the drains for easy identification (red for hyd, black for oil or something)--everything underneath is all gray. I noticed the eng oil dipstick is really yellow but when they painted the eng it got painted gray also. If they color coordinated the dipsticks w/the drain bolt that would be great for us new owners--kind of like they did w/computer connections. Of course this would cost more $.
So far, I like the tractor and hopefully will get the BH issue fixed soonest. I have been clearing land of these Yaupon bushes and getting used to FEL. I am learning as I go. I never thought the tractor would feel so "tippy" and got a good scare. I probably wasn't close to tipping but don't know--felt scary though. Had to get off the tractor for about 5 min. Good thing my land is mostly flat, can't imagine working these in hilly areas. Just uneven ground can give me a thrill. Also, working around trees I have seen that u have to be careful about limbs falling and such. The tractor has been fun but I can't really compare it to another tractor since this is my first. Since I am so unexperienced, I have taken it fairly easy and it would be nice if I really knew the tractor limits. Guess I will learn that as I learn my own limits.
The tires were loaded w/water at the dealer (it doesn't get below freezing too often here and hardly ever sustains below 32* long). I am not sure what the width of the wheels are. I guess I need to learn that eventually since if I put in crops, they may need to be adjusted. BTW, do u have to jack the tractor to adjust the wheels or do folks use the FEL to hold the front wheels up? What about rears, since we have BH can u use the support feet? What do folks use to support the tractor when the wheels are off the ground? I have something for my autos but they aren't even close to being rated for the weight of the tractor.
Again, I will try to get some pics out and will write a report when I get more time on it. So far about 15 hrs. If I am lucky, will get some seat time this weekend too. I am off to Troy State U to take my boys to a college--part of the college intro process and visiting different schools. Troy also is giving us tickets to the AR game tonight so my two football players can see a college game again. Only other one they have seen is Air Force.
Keep the info coming. I am having fun reading and getting practical experience. This morn my wife scolded me for spending so much time on this. Any techniques for getting out of the doghouse??
rob
