Where is AltaVista
   / Where is AltaVista #2
woodlandfarms said:
I was wondering if he got his problems resolved...
Thanks for the concern, ;)
Some of the problems. The oil (hydraulic) leak is very minor, now, it was in the "pressurized" unit mounted at the rear of the engine compartment. Instead of pouring out fluid, it now only drips here and there.
The brush kit came in for the alternator (generator?). It kept popping the circuit breaker, but didn't shut off the engine, this time. After about an hour, it stopped popping the cir-breaker. It runs fine but the voltage gauge runs high, around 15v while running. I ran it about 6 hours on a job and it didn't breakdown. So for right now its usable.
I'm gonna be servicing it soon, might switch the engine over to Amsoil to help with the cooling.
Glad things are shaping up for you on this one. Spring is fast approaching (I guess if you live in the east it is already here?) Out west it is bad news. Day Laborers who would work the farms are flooding the cities.
Love to hear your results with Amsoil.
Carl
   / Where is AltaVista #4
Carl
I have had Amsoil in the engine for a couple of years. My impression has been that it starts slightly faster in the cold, and runs slightly cooler, but I have nothing but a feeling, which might be wishful thinking to justify the cost. I haven't yet put in the Amsoil Hydraulic fluid.
   / Where is AltaVista #5
One of my trucks, the 97 Dodge 2500 CTD had always had Amsoil in it. (I knew the prev. owner). I bought it at 205K miles. I have two other Dodge diesels, the one that was amsoiled cranks over much, much easier than the other two..one os a 97 12v Cummins just like it, but with 265K miles.
Unfortunately I had to switch it back to dino oil..too expensive to keep amsoil for just that one truck.
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A53472)
Kubota 24in Quick...
2014 Ford Taurus SE Sedan (A51694)
2014 Ford Taurus...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
Dry Gel Hydration Unit (A53843)
Dry Gel Hydration...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2008 Ford F-550 Reading Enclosed Service Truck (A52377)
2008 Ford F-550...
