Where did my oil go???????
   / Where did my oil go??????? #1
LabLuvR
SC
Kubota MX5400
I just had to put close to a gallon of hydraulic, tranny oil in my 2000 GST L3710. When the dealer brough it out to me, three weeks ago, the glass was about 3/4 to half filled with oil. I assumed since this was hydraulic/tranny oil the consumption would be very low and did not pay close attention to the oil level til yesterday. My guess is that I have put around 30 hours on it since delivery. Total hours on the tractor now is 501 and everything seems to be in great working order. I have also searched and cannot locate any leaks. Was I wrong in assuming consumption would be very low? One thing I do know I will check the level every day from now on!:D Is this amount of consumption normal? Thanks!
   / Where did my oil go??????? #2
My guess is that the oil has taken the place of trapped air in the system. Very common in new machinery
   / Where did my oil go??????? #3
Got any implements that you are using? maybe connecting and disconnecting hydraulic lines? Maybe you have a leaking fitting on your FEL. It's highly unlikely the tractor itself is the culprit. If you checked it with any cylinders extended (like on the FEL), the oil in the sight glass would be lower. I had a 3710 previous to the 5030. It's a long, long way between the bottom edge of the sight glass and the bottom of the sump. The oil level will even fluctuate due to the temperature of the oil.
In closing, I'd presume the oil is still there, that is, unless it spilled on the ground when you changed implements.
I always keep a spare 2.5 gallon jug of UDT around just in case. Even though the hydraulic quick disconnects are poppet style on the 5030, I still loose some every time I change a hose.
No implements used other than bushhog,plow and disc. Maybe the air theory or temperature theory is correct. With no leakage anywhere, it sure is a mystery. At least I haven't found any in the radiator.:D
   / Where did my oil go??????? #5
I'll bet that the oil for air theory is at work here. If the dealer did not "work" the machine then the pump and all the related tubing, passages, and all that good stuff needed to be filled with fluid!
   / Where did my oil go??????? #6
LabLuvR:
I don't think there would be any in the radiator. There is no oil to water cooler on the engine.
Labs, huh?? We have a few too. A golden a black and a chocolate. All in the house and right now, all on the couch and loveseat.
   / Where did my oil go??????? #7
now that u have worked it, top the oil off according to the manuel and then watch it from there. that oil should remain constant UNLESS u have a leak.
Oil in the radiator was just making light of my situation. You have got to love a lab. They are just too smart! My black lab is asleep on my bed. What a bed hog!
I will keep my eye on the glass from now on. I would not expect to have to add anymore for sometime, unless I find a hidden leak. Thanks for the info guys!
   / Where did my oil go??????? #9
One more thing I learned about that sight glass. It is very sensitive to changes in slope. Try to check it in the same place, or at least on a known level, hopefully paved, surface.
   / Where did my oil go??????? #10
<font color="blue">I don't think there would be any in the radiator. There is no oil to water cooler on the engine.</font>
I think that Daryl is right, you can't get the hydraulic fluid in the radiator. Having said that, you can get it into the engine oil. If the seal goes out of the hydraulic pump, it can dump into the oil sump.
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A53843)
2006 V.E...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
ATLAS XAS110 COMPRESSOR (A52472)
ATLAS XAS110...
2016 CATERPILLAR 730C2 OFF ROAD DUMP (A51246)
2016 CATERPILLAR...
11 SERVICE BODY BED (A53843)
11 SERVICE BODY...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54607)
2019 FREIGHTLINER...
