where can i get middle buster implements?
   / where can i get middle buster implements? #1
howardx
I have a middle buster for my bx-24 that i user for some basic trenching activity, but i was wondering where i could get some different implements for the middle buster.Specifically, something to dig a more precise , straight wall trench for some walkway edging. TSC doesn't seem to carry this stuff. I remember from back in my youth,changing out the type of plow share all the time..Where do you get this stuff?
   / where can i get middle buster implements? #2
Don't know about middle buster add-ons, but if you have an idea for what you need, sketch it out and fabricate it or take it to a welding shop and see what they can do for you.
If you can see it in your mind, it can be done.
Good luck.
   / where can i get middle buster implements? #3
hmmm, TSC has some chisels and stuff, other COOP's and tractor places should have others. Don't know the exact type you are talking about. Ususlly it's just something to get the hole dug then clean it out. IE I used a turning plow for my water line, got me down a ways but I needed to clean out the stuff that fell back in. Still faster and cheaper than hand or renting.
Good Luck,
Rob
   / where can i get middle buster implements? #4
Hi: I got my mid-buster from TSC last fall for apx $120. They also has a single shank sub soiler for about $150 IIRC and may both for $180. I just figured I would go the the parts section and order the single shank tooth for $18.10+shh. Know they are in Northeran Tool cat in several weights/setups.
Guess I don't know what else you are looking for.
Pat R
really, i guess that about it. I would just like to be able to make a small,well defined trench to put some bricks in, standing up. I don't know if a chisel type blade would be fine enough, but maybe so. It's probably worth the $18 gamble to see.I'll check at northern tool.
thanks again,
howard
   / where can i get middle buster implements? #6
Hi Here is link to TSC for what I got
Tractor Supply Company - KING KUTTER® MIDDLE BUSTER
And going to king kutter web site under parts see item 2 for some reason it won't let me cut/paste addy line so just register item is SUB Don't know if Northeran will sell parts as they just retail somebodiy elses prod
View Shopping Cart
Sub-Soiler Parts Sales
Purchase PartNo. Part Number Price Weight
1 500001 8.37 2.10
2 177006 18.15 2.10
3 503002 9.74 0.61
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
2011 GMC SIERRA 2500 (A52472)
2011 GMC SIERRA...
2015 Volkswagen Passat SE Sedan (A50324)
2015 Volkswagen...
2019 FORD F-250 (A52472)
2019 FORD F-250...
2012 Ford Fusion SE Sedan (A50324)
2012 Ford Fusion...
