Where can I get Broken BX Axel Shafts?
   / Where can I get Broken BX Axel Shafts? #1
Tractor Seabee
Elite Member
Port Orchard WA Kitsap Peninsula, West of Seattle
Kubota BX25
Looking for a couple broken axel shafts for a BX25. Probably several other Kubota's have the same wheel pattern also. All I plan to use is the wheel flange part to build some wheel base extenders. That way I do not have to be meticulous getting the bolt holes placed and threaded on the wheel side. I'll use nuts and bolts on the existing flange so line up is not as critical and I'll have the scrap flanges for a pattern. I will just weld a 4" piece of XH pipe between the two flanges to build the extenders.
My dealer's shop does not save that stuff and changing the axels is not a common job they see a lot of. You guys out there ask around when you are at dealers shops.
Ron
   / Where can I get Broken BX Axel Shafts? #3
can also look for these in junk yards, should be pretty cheap to pull the rear axles and build from them too
Ford Rangers up to the mid 2000's
Ford Crown vic and mercury marquis old through to 96 or so
Ford Mustangs 94 and up
Dodge Dakota 8-90
Dodge 2wd 1/2ton truck and van and ramchargers 71-85 (could be a mix depends on axles used)
Chrysler full size cars 68-87 or so
and likely a few more
   / Where can I get Broken BX Axel Shafts? #4
Jeep Wrangler TJ 97-06 have 5 on 4.5 bolt spacing and are notorious for breaking axles too.
   / Where can I get Broken BX Axel Shafts? #5
I wouldnt' bother looking for them broken. You should be able to pick up axles from the list that Crash had fairly inexpensively. Heck...pick up a set of wheels while you're at it. Maybe a set of dodge truck wheels on the 'bota. lol
   / Where can I get Broken BX Axel Shafts? #6
Crash gave a good advice for the rears. it might be something you can work with. I doubt you would see ANY broken BX rear axles.
   / Where can I get Broken BX Axel Shafts? #9
On a 5 lug pattern start at the center of one stud, skip a stud and mesure to the next center. add 1/4 inch that is you bolt pattern. Example if you mesure a 5 lug chevy you will get a mesurment of 4and 1/2 inch from center of stud. Add 1/4 inch for 5 on 4 and 3/4 inch.... This only applys to SAE patterns. Metric is alittle different.
2024 JCB 220XLC EXCAVATOR (A60429)
2024 JCB 220XLC...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2434 (A60432)
2434 (A60432)
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
SWICT 84" SKID STEER BUCKET (A60430)
SWICT 84" SKID...
