Where can I find...
   / Where can I find... #1
RickO
Central, Ohio
Kubota G1900
... an engine to fit a JD GT242 Garden Tractor? It has a 38" deck. I wouldn't even care if it were used. I prefer to put the same motor that came stock which I think is a 14hp Kawasaki.
Thanks guys
   / Where can I find... #5
The 14 HP air cooled Kawi used on the GT242 looks to be out of production and sold out at most places. I would call either one of the above suppliers to find a suitable Kawi engine to retrofit, and take advantage of probably being able to upgrade to a 17 HP engine in there. That is one good thing with vertical shaft engines, finding retrofits is much easier than with a horizontal mounting. With vertical shaft it's mainly just finding similar outside dimensions and the right length and width of the crankshaft end. Then it might only involve drilling some new holes in the mounting plate, hooking up control cables and wiring and away you go.
-Fordlords-
Yes, I saw that they were out of stock. I don't need the mower, just bought it cheap at an auction - so I have time to look. Thanks for the advice.
2015 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2015 GENIE...
ROLOFF 500 BBL FRAC TANK (A53843)
ROLOFF 500 BBL...
TEST YOUR BID BUTTON! (A52706)
TEST YOUR BID...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
KUBOTA M7-132 (A53084)
2015 CATERPILLAR 930K WHEEL LOADER (A51406)
2015 CATERPILLAR...
