Where can I find?...
   / Where can I find?... #1
Dano83
Port Crane
John Deere 670
Where can I find an aftermarket water temp gauge and sensor for my John Deere 670 compact? Local parts stores only carry ones that are standard fittings and being a yanmar 3cyl diesel its a metric fitting that goes into the water pump for the sensor. Found this TEMPERATURE GAUGE KIT - Sale!: Yanmar Tractor Parts but $38 with $12.99 shipping im scared if its not the right one! :)
Dano
   / Where can I find?... #2
Greetings. I wanted a way to check my MF temperature gauge. I went on ebay and purchased an in-line temp gauge adapter. This is a piece of pipe that you install in your top radiator hose with a threaded bung for a mechanical temperature gauge sending unit. I then went to www.dbelectrical.com and purchased a temperature gauge. Then mount the gauge in some out-of-the-way place so that it will not distract for the appearance of the tractor. Before installing gauge, double check its accuracy with a pot of water on your stove. You will need to know the diameter of your radiator hose. The total cost was about $40.
Hope this helps.
bigbyrd
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
(2) 330 GALLON POLY TOTE (A51248)
(2) 330 GALLON...
DEWALT 4400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 4400 PSI...
2024 JOHN DEERE 3039R LOT IDENTIFIER 55 (A53084)
2024 JOHN DEERE...
