When was it made??
   / When was it made?? #1
CVHoss
S.E. Kansas
J.D. 4400
A search of the forums looking for the words that I thought would key on this question has provided no results, so I hope I'm not re-hashing an old question. Can anyone tell me how to read the serial number on the 4000 series tractors to know when it was manufactured? If my tractor serial number is LV4400H******, do the L,V, or H determine the year and month of manufacture?
Thanks for any help available.
Hoss
   / When was it made?? #2
Hoss, this is how its explained in my parts catalog.
Example: LV4100G110031
LV- Factory Designation = Augusta, GA
4100 - Model/ Machine Designation = 4100 Compact Utility Tractor
G - Configuration Code =
G: Gear Transmission
H: Hydrostatic
N: Narrow (Gear Transmision)
C: Gear Transmission (European)
D: Hydrostatic Transmission (European)
110031- Serial Number
1998 Models 110031-210000
1999 Models 210001-
My copy was published in early 99 so that was as far as the yr/serial numbers went there. My tractor was ordered and delivered in 00. The serial number begins with 31xxxx.
Maybe it can help some.
DFB
   / When was it made?? #3
Actually,
The C stands for coller shift, S for sync reverser, P is power reverser, H for hydrostatic, and all the European models have an E is the plate.
   / When was it made?? #4
I have a john Deere lv4100 serial number 4310434 what year is it and where can I find what it is worth
   / When was it made?? #5
Ansley
Not familar with the lv4100 model. There is a JD 4100, compact utility. But don't know if that is what you are talking about here. Confused by the lv prefix.
   / When was it made?? #6
Ansley
I do not know but the tag on on the frame has LV 4100 it is a JD
   / When was it made?? #7
I assume you are reading the serial number incorrectly. It probably reads LV4100H310434. If so, it was built in November 1999. Originally sold in May 2000, resold in august 2001 and again in November 2007. Prices on Tractorhouse.com range from $6000 -- $12000 depending on location, condition, hours.
   / When was it made?? #8
Ansley
I do not know but the tag on on the frame has LV 4100 it is a JD I know the LV stand for were it was made Augusta,ga
   / When was it made?? #9
Thank you very much I will check.the number again
2013 Ford F-250 Knapheide Service Truck (A51692)
2013 Ford F-250...
Ford Pickup NR (A50323)
Ford Pickup NR...
2017 GRAND DESIGN RECREATIONAL MOMENTUM (A53843)
2017 GRAND DESIGN...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51694)
iDrive TDS-2010H...
2014 MACK GU713 WINCH TRUCK (A53843)
2014 MACK GU713...
2015 Kia Sportage LX SUV (A53117)
2015 Kia Sportage...
