When to stitch weld vs solid bead?
   / When to stitch weld vs solid bead? #1
Haywire
Veteran Member
Central Kentucky
Tractorless :(
Title says it all. When do you stitch?
Ian
   / When to stitch weld vs solid bead? #2
I use a stitch weld to.avoid distortion.of.thin metals. Everything else I do solid
   / When to stitch weld vs solid bead? #3
I stiched the top on my welding table. It is 1/4 inch plate, and it still warped a little bit.
   / When to stitch weld vs solid bead? #4
Continuous weld when a seal in needed, enough stitches when strength only is needed. Sometimes they amount to the same thing. Long welds can promote unnecessary warping. MikeD74T
   / When to stitch weld vs solid bead? #5
I generally use skip welds with anything that is going to have a ripping effect. Once a cracks starts it can rip right through a continuous weld, but it is sometimes harder for the crack to start in a new weld.
Distortion is another good reason, plus back stepping any welding to help with distortion.
   / When to stitch weld vs solid bead? #7
What's that? Is that staggering the stitches side to side like this? _ッ_ッ_ッ_
Back stepping is one of the most important techniques you need to know to be a top notch weldor. You have to plan out your welding before you ever start, you can't just drop your hood, and start pouring wire / rod. Or you'll end up with a big mess!
This is back stepping and skipping around. Two very important things to do, to counter warping.
Ah, ok... I'm off to the shop to warp up some metal. LOL
thanks
   / When to stitch weld vs solid bead? #9
Maybe this is a better illustration of what I'm trying to say. I left a little gap between welds on purpose.
Welding vertical up will really get hot at the top of the plate if you start at the bottom and weld all the way to the top. Back stepping breaks up the heat line. I back step everything I weld, but I also try to skip around a lot too!
   / When to stitch weld vs solid bead? #10
Hey Shield Arc, Thanks for the diagrams you posted. As a beginner welder this is of great help. I just completed a bracket to bolt to my ballast box for a 2 " receiver (grnspot110's patent :cool:) and did have some distortion issues. Nothing that would affect anything but something I notiiced and want to be able to correct in the future.
2023 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A42744)
2023 Chevrolet...
2012 FREIGHTLINER M2 STAKE BED 24’ LENGTH (A43004)
2012 FREIGHTLINER...
17in Excavator Bucket (A44391)
17in Excavator...
2000 Sterling L7501 Petersen RL3 Rear Mount Grapple Truck (A42742)
2000 Sterling...
WICHITA TANK 500BBL WHEELED FRAC TANK (A45046)
WICHITA TANK...
2009 Kenworth T800 Truck, VIN # 1XKDP4EX69J245973 (A44391)
2009 Kenworth T800...
