When to do an oil change
   / When to do an oil change #1
doakster2
New Brunswick, Canada
LS S3010
Hi. I just bought an LS S3010 last August. It was used, but barely (300 hours on it). An oil change was done before I bought it, and I've only put about 30 hrs on it so far. The manual gives the intervals for oil changes (I think it is every 300 hrs). Where I don't use it much, should the oil be changed more frequently? I know with cars they say every 6 months if you don't drive enough to meet the mileage limit. What is the recommendation?
   / When to do an oil change #2
I usually change the oil on my equipment (tractors and small engines) every spring, and that seems to work fine.
   / When to do an oil change #3
Generally accepted change interval for any vehicle or equipment that does not get a lot of hours is to change once a year.
   / When to do an oil change #5
If you really want to know for certain you'll have to have an oil analysis done.
Mace nailed it. A lot depends on your oil quantity AND time AND usage AND if it's under warranty
Example - My Ford F350 7.3 takes about 4 GALLONS of oil and everybody recommended changing between 3,000 and 5,000 miles. I did several Used Oil Analysis (UOA) and it was good for over 18,000 miles and almost 2 years.
If it's not under warranty and it only takes a few quarts change it whether it needs or it not. A UOA costs about $20. If it takes $100 worth of oil and it does not need changing then you are throwing your money away.
Thanks for all the input! Sounds like it probably wouldn't be a bad idea to change the oil once a year. That's kind of what I was leaning toward
toward.
   / When to do an oil change #7
My tractor takes 1 gal of Rotella and the oil filter total is $22. It get changed every spring. This year there was 80 hr on it.
   / When to do an oil change #8
Once a year for small equipment and seldom used vehicles works great.
Chris
   / When to do an oil change #9
yeah, I am on the once a year gig also. I don't put over 75 hrs on in a year, so it gets oil, filter, fuel filter every spring.
   / When to do an oil change #10
I'm in the once every 3-5 year group since I put low hrs on my equipment and when I use it it is run hot and not put away cold.
DEWFPO
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
2022 CATERPILLAR 926M WHEEL LOADER (A51242)
2022 CATERPILLAR...
UNUSED FUTURE EQUIPMENT SEAT (A51244)
UNUSED FUTURE...
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
1998 VOLVO A40 OFFROAD DUMP TRUCK (A51242)
1998 VOLVO A40...
2011 Nissan Rogue SUV (A50324)
2011 Nissan Rogue...
