when to cut
   / when to cut #1
horses2
Bronze Member
Westminster, Md
Kubota M471D
I have a farmer that cuts & bales my hayfields. It is a good arraingment, he does the soil tests 2x/yr, and has the fields fetilized based on the tests, and and sprayed for weeds usually 1x/yr. Our crop split works for both of us. I am concerned that he seems to let the hay (orchardgrass/timothy mix) mature a bit too long for my (actually my wifes horses) tastes. I believe the issue is labor and scheduling.
What is the opinion of everyone on the best time to cut a timothy/orcardgrass mix? the field this year has been soil tested and fetilized, and with some recent good weather, the hay has jumped to about a ffot tall right now.
Am I correct in thinking the hay should be taken right before seed heads develop? last year, the weather prevented us from taking the first cut until way late. The upside was the seed I took off the haybine was respread and germinated well and that area is quite lush this year.
thanks,.
   / when to cut #3
You want the heads to be about 1/2 bloom no more than 3/4. When the seed head has developed fully all the nutrients are in the seed so basically you are feeding grain with straw.
   / when to cut #4
Its all about weather and time.
If you can condition, roll and wrap you can shorten the time.
If you square just wait or grow a different hay
Kinze 840 Grain Cart (A50514)
Kinze 840 Grain...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
JOHN DEERE 4100 TRACTOR (A51243)
JOHN DEERE 4100...
66in Light Material Bucket Skid Steer Connection (A52128)
66in Light...
2003 Pierce Fire Truck (A50323)
2003 Pierce Fire...
2021 CATERPILLAR 317 EXCAVATOR (A51242)
2021 CATERPILLAR...
