When is too many lights to many.
   / When is too many lights to many. #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
My lights on the trailer were getting a bit 'broken' so I decided to upgrade all to LED's. Question is I want to add a few extra running lights. Is added two or four more running lights going to put a strain on the battery or alternator?
   / When is too many lights to many. #2
As long as you use LED's, add as many as you want.
An LED only uses about 1/10th of a normal light.
   / When is too many lights to many. #3
Yep, Copperdog is right. You can add as many as you can afford.
Remember, unlike light bulbs, led's do have a polarity. If one does not light, check that first.
   / When is too many lights to many. #4
If you are commercial...just remember every light you add is just another potential fine if it is NOT working...:rolleyes:
Checking ground is a bear on them. I have one issue on the ground already so I just pop riveted the ground to the trailer.
   / When is too many lights to many. #6
Ive just put LED's on the tail of my hybrid F250 . Because the donor car i used for the conversion had Can Bus wiring , the cruise control would not work , the stop and reverse lamps stayed illuminated and the blinkers where blinking too fast . All is well now though as i fitted resistors too the wiring to put a load on the computor . For anyone having this trouble with late model vehicles with LED's fitted . The computor sends a low voltage signal down the line to check for blown bulbs (a systems check). This voltage is enough to illuminate the LED's and cause all the problems above .
I would hope that would not be an issue on a trailer however. I replaced all the lights on the trailer but I dont see how the truck, a Yukon XL, would be able to know if a bulb is blown.
   / When is too many lights to many. #8
No , it only checks the vehicle . Can Bus wiring is the latest idea to cut down on the amount of wires in a vehicle . One wire may work the right hand blinker , the brake lights , the fuel tank sender etc . The computor sends a signal down the line and waits for a response . If a tail light bulb is out for example , the computor senses the lack of resistance from the blown filament and if so equiped will illuminate a bulb out warning light on the dash . It's this low voltage that is sent down the wire that causes problems with LED's . Because they draw little current the computor does not know they are there and acts as if a bulb is out . It will stop the cruise control working as the brake light switch is used for the cruise and if regular tail lights are swapped for LED's the computor looses the signal . Inline resistors trick the computor into thinking regular bulbs are installed .
   / When is too many lights to many. #9
I never like to use a body ground with trailer lights. It will fail at some point. Wire all your grounds and power connections, and solder them. Then use either shrink tube or liquid tape. No more screwing around trying to get them to work in the dark, or the cold. :eek:
   / When is too many lights to many. #10
I replaced most of the lights on my dump with L.E.D.s (except for the fender light which is half amber, half red). I buy my lights at a "chrome shop" (big truck accessories) that stands behind what they sell. I had one circuit die on a tail light. Brought it back to them, they replaced it free of charge, no questions asked. The light had to be more than five years old. Its worth spending slightly more for a good brand name light........ they have a million mile warranty.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2018 FREIGHTLINER...
23169 (A50324)
23169 (A50324)
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2007 INTERNATIONAL 4300 ROUSTABOUT (A52472)
2007 INTERNATIONAL...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51246)
2019 CATERPILLAR...
378808 (A51573)
378808 (A51573)
