Wheelhorse B81-8HP rearend oil check
   / Wheelhorse B81-8HP rearend oil check #1
Ken Thomas
Wheel Horse (Torro) SB-421 8 SPD Lawn Tractor
I know someone who has a Wheelhorse B81-8hp lawnmower or tractor who asked me if I knew how to check the oil level in its rearend.
He says there is no dipstick and seem to have only a drain plug.
Does anyone know how to check the oil level and add oil if necessary.
I assume that above the drain plug , there is another plug that you remove upon filling (how & where that is done is questionable) and filled at that plug untill the oil comes out.
The same principle is used on the Areins snowblower main auger differential.
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
434669 (A48836)
434669 (A48836)
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A53473)
2019 New Holland...
