WHEELBASE REDUCTION
   / WHEELBASE REDUCTION #1
TEXASHUNTER
Boy, do I need some advice on this. I own a 2005 Mahindra
5500 2WD. The outside back tires show to be 77" to the edges.
My trailor is 77." It is a 3500 twin axle rated at 7000lbs. They all
seem to be 77" wide. I know it's under rated for the tractor--but
I want to reduce the width of the outside back wheels. No one
seems to be able to tell me exactly how much it can be taken in.
Also, can I do it or is it a dealer job. HELP PLEASE!
   / WHEELBASE REDUCTION #2
I don't have book in front of me but I think you can reduce wheel base to 72"
or less. This job requires ability to safely jack up and block both sides of tractor and to safely move the very heavy wheels. If your tires are filled I would not even think about trying myself.
Think of the wheel as bowl shaped. If the inside of the bowl is bolted to the axle, then you have the narrowest wheel configuration. If the bottom of the bowl is bolted to the axle then you have the widest configuration. In addition to changing the wheels, the rim of the tire can be bolted on the inside or outside of the wheel which also narrows or widens a few inches. In my case I was able to swap the two rears on a 6500 FWD and go from narrowest to just shy of widest with no changing of the rims. I would not try this myself again without more help and a hoist or something similar to assist. If took me a few hours to switch my wheels and I am certain that it was not too safe.
Hope this is clearer than it seems.
Okay, one more time for an idiot. I think I got the wheel
thing-turn the wheel either in or out-now tell me about
that rim thing again. Thanks.
   / WHEELBASE REDUCTION #4
Checked the Mahindra site, they list width as 77.4", this may be as narrow as will go. Also, we are talking about reducing width, wheelbase will be the measurement between front and rear wheels.
Yes, I do mean the width. Sorry.
   / WHEELBASE REDUCTION #6
At least on my 6500, the rim bolts onto the wheel which is concave. You can bolt the rim on the inside or the outside of the wheel. The rim has what looks like built in spacers that are probably 2" (from memory) on one side of the rim. Therefore, rim on inside versus rim on outside of wheel base changes width by more than the thickness of the metal the wheel is made of. Hard to describe without looking at the rims. I think technically, because you could take the tire off the rim and flip the rim Mahindra gives 6 or 8 possible widths.
   / WHEELBASE REDUCTION #7
If you flip the rim without taking tire off, your ags will be running backwards, so with out changing tires you have 4 possible widths. Concave in or out and rims on inside or outside of the flange of concave.
Thanks, you have me started.
   / WHEELBASE REDUCTION #9
Hey.. I was going to point out the tread issues:( u got all the fun..lol My guess is that they are as narrow as they'll go if 77 is listed on the site. Narrowest is usually the spec listed.
   / WHEELBASE REDUCTION #10
Uh....when you swap concave for convex rims and tires............you also swap sides to keep the tread going forward. Unless you are doing all your work pushing (as in reverse) a boxblade, as in piling up brush and logs to burn.
My 6520 has 5 different tread widths, with the max. (in the Ops manual) being 75.4 inches. Which is not correct as my trailer is 83 inches wide and I have about 3 inches to spare.
hugs, Brandi
UNUSED SWICT 78" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 78"...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2017 BOMAG BW145D SMOOTH DRUM ROLLER (A51242)
2017 BOMAG BW145D...
Wolverine Quick Attach Screening Bucket (A50514)
Wolverine Quick...
