Ballast wheel weights
   / wheel weights #1
Anonymous Poster
Epic Contributor
I have just finished fitting some wheel weights to my DK50. I bought weights from a tractor wrecker they came off a fiat they fitted very easy. there were 3 holes in the weights just matched and drilled the rims and bolted back together weight about 70kg ea. while i had the rims of i also modifed the 4wd lever, where the arm fits over the shaft that goes into the gear box i welded a extention shaft to the existing arm, bolted a bracket to the frame oF the tractor and fitted a bush for the extented shaft. the reason i have done this is because it is difficult to engage and disengage due to its poor design (to much side pressure.) sorry about the goobly gob, i have tried, attachment may explain or may make it even worse.
vin
2016 Wilson Hopper Bottom Trailer (A50514)
2016 Wilson Hopper...
2007 JOHN DEERE 310SJ BACKHOE (A50458)
2007 JOHN DEERE...
2016 Ford Escape 4WD SUV (A50324)
2016 Ford Escape...
(3) 14' X 14' ROLL UP DOORS, W/ MISC BRACKETS (A51244)
(3) 14' X 14' ROLL...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2025 JMR 36in Mini Skid Steer Bucket Attachment (A50322)
2025 JMR 36in Mini...
