Ballast Wheel weights available for 6500 4WD?
   / Wheel weights available for 6500 4WD? #1
Tim_in_IA
Platinum Member
Eastern Iowa
Kubota B7610HSD, Mahindra 6500 4WD, JD 440ic crawler, 2 560 farmalls.
Is anyone running a 6500 4WD with Cast weights on the rear tires? After much consideration and looking at my leaking M Farmall wheels in the corner of the building I decided not to go with the fluid in tires. I don't want to start a huge thread on fluid vs. weights, as I already saw that it's been done before, but I would like to know if weights are available. Or is this an aftermarket thing just based on tire size? Are weights generic more or less nowdays?
My dealer has never seen weights on the 4WD versions. They are still checking in on it for me but I thought I would ask around.
   / Wheel weights available for 6500 4WD? #2
Yes, rear weights are availible for 6500 4wd at least with ags not shure about with r 4's, they are approx 115 lbs ea. We usually put at least 2 some times 3 per side works well. If interested i can ship them direct to you. 1-866-393-0642
Scott
   / Wheel weights available for 6500 4WD? #3
Tim,
I had them on my 6500 that I got rid of before.
Brian /forums/images/graemlins/cool.gif
Thanks Scott,
I have ag tires. I will see how the local dealer does and if they can't get them I'll be in touch. What are they roughly a piece? What is the maximum or is there one? Do you know if they can still be mounted if the wheel is inverted?
Dealer just contacted me. They can order them from Texas. They are waiting till the tractor is built. I think I must be getting a little anxious. /forums/images/graemlins/smile.gif Now that it is warming up outside I am having a hard time waiting on my projects!
10' Feed Bunk (A50515)
JMR 72" Root Grapple (A50121)
JMR 72" Root...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
1989 W-W Stock Trailer (A50514)
1989 W-W Stock...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
