wheel weight limits?
   / wheel weight limits? #1
daTeacha
Veteran Member
Funk, Ohio
I went to the junk yard yesterday and picked up some scrap steel discs for about a quarter a pound with the objective of making some wheel weights. The factory cast iron weights sell for $88 per hundred pound weight and are set up for two per rear wheel with Ag tires.
When I checked out of the junk yard, I had 560 pounds of steel in the truck. I already have a 900 lb. rear weight on the 3 point hitch of my DX29. I'm wondering if the factory limit of 200 lb per wheel is critical or just a related to the fact that they hold them on with 5/8 carriage bolts? Can I hang a couple hundred pounds on each wheel plus the 900 on the hitch? I don't see where it should be a problem, but I'm wondering what you guys think.
I'm wanting to add the wheel weights since I have lifted a rear wheel now and then working with the loader and quartering uphill or down.
   / wheel weight limits? #3
There is place where you start to get a diminishing return by adding more weight. When that point is achieved, from then on the tractor will experience increased wear and a greater thirst for fuel. I always say to add weight but don’t go far enough to make the tractor sluggish and non-responsive.
   / wheel weight limits? #4
   / wheel weight limits? #5
</font><font color="blue" class="small">( There is place where you start to get a diminishing return by adding more weight. When that point is achieved, from then on the tractor will experience increased wear and a greater thirst for fuel. I always say to add weight but don’t go far enough to make the tractor sluggish and non-responsive. )</font>
At some point.....GET A BIGGER TRACTOR!
   / wheel weight limits? #6
   / wheel weight limits? #7
Here is a picture of a tractor with a few wheel weights on. I think that it is almost at it's limit. /forums/images/graemlins/grin.gif
   / wheel weight limits? #8
   / wheel weight limits? #9
Great Picture! /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
   / wheel weight limits? #10
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A53843)
2013 XLR...
2015 CAT D5K2 LGP (A47477)
2015 CAT D5K2 LGP...
Light Tower (A52377)
2018 Lexus IS300 Sedan (A51694)
2018 Lexus IS300...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
LEEBOY PF1510B ASPHAULT PAVER (A51406)
LEEBOY PF1510B...
