Wheel spin
   / Wheel spin #1
Rocky Hoffler
Platinum Member
N. Central Fl.
Kubota L4600
I recently purchased a DK 4710 hat and have noticed that if I am on uneven ground I get wheel spin I didn稚 have this problem with Kubota I had is there a limited slip front differential just asking for info thanks
   / Wheel spin #2
In 4WD you will only have two wheels pulling in "slippery conditions". One front - one rear. If your have rear differential lock - you might have three wheels pulling - one front - two in the rear. You probably will not find front limited slip/differential lock on smaller tractors - OEM.
Some larger agricultural tractor will have a type of front locking system.
Check the tire pressure in your front tires. Too high a pressure can lead to wheel slipping.
2015 Ford F-750 Box Truck, VIN # 3FRNF7FA8FV745627 (A51572)
2015 Ford F-750...
Unused 2025 CFG QK16R Mini Excavator (A50322)
Unused 2025 CFG...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
2018 Ford Ecosport S SUV (A50324)
2018 Ford Ecosport...
John Deere 6175M (A50120)
John Deere 6175M...
2017 Ford F-450 XL (A50120)
2017 Ford F-450 XL...
