Rear Finish Mower wheel spendles
   / wheel spendles #1
Slagiatt
Ford 1720
I've perchase two of the 72" finish mowers last fall one Woods,the other is a Bush Hog rear dishcharge. i consider both mowers to be well built brands, but both have bent spendles on their wheel mount's. most of the one's Ive look at seams to a common problem. Take's about a hour to strighten these wheel spendles good enough to reuse. And of corse like most metal once bent just get's easer to been the next hoe in the yard. must be a better way to trolly these mowers
   / wheel spendles #2
Sorry to hear about the wheel spindles bending on you.
The only way to correct this issue is to add additional
wheels and spindles by pairing them up.
What type of bearings are they using if any?
   / wheel spendles #3
Most finish mower wheel forks bend because the owners don't grease them. They can't caster freely, so the forks get trashed.
2018 JOHN DEERE 333G SKID STEER (A51242)
2018 JOHN DEERE...
Kinze 3600 16 R Planter (A50514)
Kinze 3600 16 R...
YALE STRAIGHT MAST FORKLIFT (A51242)
YALE STRAIGHT MAST...
UNUSED KJ 11' X 19' SINGLE STEEL CARPORT (A51244)
UNUSED KJ 11' X...
Agco S150 Manure Spreader (A50774)
Agco S150 Manure...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
